extract flat pattern from assembly file
I want extract flat pattern from assembly file only with one click.
Please guidance me
Owner2229
Hey, you mean for every sheet metal part in the assembly?
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
yes
like the attached pic
Owner2229
So, not a flat pattern, but folded sheet metal and you want to place them all in one drawing (one view per part)?
That shouldn't be hard, but the dimensions would be.
I guess the labels are in format:
<part name> <pieces in assembly> <thickness> <length>
What's the difference between "H:1007" and "L:1007" ?
Btw. there's one dimension missing on "front head top" part.
Mike
