External rules/Error Unable to cast COM object of type
antonio.silvaluna
antonio.silvaluna
I have inventor 2020 and I made this code to change the sheetmetal defaults in all sheetmetal parts in an assembly
But this error appears when I run the code.
Sub Main()
	Dim thisAssyDoc As AssemblyDocument = CType(ThisDoc.Document, AssemblyDocument)
	ChangeToTest(thisAssyDoc)
End Sub
	Sub ChangeToTest(assemblyDoc As AssemblyDocument)
		For Each subCompOcc As ComponentOccurrence In assemblyDoc.ComponentDefinition.Occurrences
			Dim oDoc As PartDocument
			oDoc = ThisApplication.ActiveDocument
			Dim oCompDef As SheetMetalComponentDefinition
			If oCompDef is oDoc.ComponentDefinition Then
				oCompDef.SheetMetalStyles.Item("18ga GA JKT (Test)").Activate
			ElseIf oDoc.SubType = DocumentTypeEnum.kAssemblyDocumentObject Then
			ChangeToTest(oDoc.Definition.Document)
		Next
	End Sub
basautomationservices
You're trying to cast the active document which is still an assembly to a partdocument.
Should be
Dim oDoc as Document
Set oDoc = subCompOcc.Definition.Document
if oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
    Dim prt as PartDocument
    Set prt = CType(oDoc, PartDocument)
    ' your code
elseif oDOc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
End if
Contact me for custom app development info@basautomationservices.com. Follow below links to view my Inventor appstore apps.
Free apps: Smart Leader | Part Visibility Utility | Mate Origins
Paid apps: Frame Stiffener Tool | Constrain Plane Toggle | Property Editor Pro
antonio.silvaluna
Thanks I will try this
WCrihfield
Just another variation for consideration.  Changed the Sub to work with AssemblyComponentDefinition directly, then no need to access the component document object at all.
Sub Main()
	ChangeToTest(thisAssyDoc.ComponentDefinition)
End Sub
Sub ChangeToTest(AssyDef As AssemblyComponentDefinition)
	For Each subCompOcc As ComponentOccurrence In AssyDef.Occurrences
		If TypeOf subCompOcc.Definition Is AssemblyComponentDefinition Then
			ChangeToTest(subCompOcc.Definition)
		If Not TypeOf subCompOcc.Definition Is SheetMetalComponentDefinition Then Continue For
		Dim oSMDef As SheetMetalComponentDefinition = subCompOcc.Definition
		Try
			oSMDef.SheetMetalStyles.Item("18ga GA JKT (Test)").Activate
		Catch
		End Try
	Next
End Sub
Wesley Crihfield
(Not an Autodesk Employee)
