External Rule to create Internal rule
vkulikajevas
vkulikajevas
How to create an External Rule, which could copy its content rule to as Internal Rule of the part?
For Example External Rule "Ext" has a line
iProperties.Value("Project", "Stock Number") = "t = " & Thickness & " mm"
I need this Rule "Ext" to be inserted into the part and named as "Int"
Sergio.D.Suárez
Hi, I usually use an external rule similar to the one I share below to add an internal rule.
You must be careful when you try to add a quotation mark character, you must duplicate it within the rule, otherwise you will have error.
Sub Main
Dim oDoc As Document = ThisDoc.Document
If oDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject AndAlso
 iProperties.Volume > 0 Then
Dim RuleName As String = "Thickness_Rule"
Dim RuleText As String = "'Example of Ilogic Rule" & vbCrLf & _
						"iProperties.Value(""Project"", ""Stock Number"") = ""t = "" & Thickness & "" mm"""
Dim RuleAlreadyExists As Boolean = False
' Define the iLogic addin
Dim iLogicAddIn As ApplicationAddIn = ThisApplication.ApplicationAddIns.ItemById("{3bdd8d79-2179-4b11-8a5a-257b1c0263ac}")
' Get the iLogic automation object
Dim iLogic As Object = iLogicAddIn.Automation
' Get the list of iLogic rules in the current Inventor document
Try
	iLogic.DeleteRule(oDoc, RuleName)
	iLogic.AddRule(oDoc, RuleName, RuleText)
Catch
End Try
	Dim EventPropSet As Inventor.PropertySet
	EventPropSet = GetiLogicEventPropSet(ThisApplication.ActiveDocument)
	EventPropSet.Add(RuleName, "AfterAnyParamChange", 1000)
	EventPropSet.Add(RuleName, "PartBodyChanged ", 1200)
	EventPropSet.Add(RuleName, "AfterDocSave",800)
'After Open Document					: AfterDocOpen                 		: 400
'Close(Document)						: DocClose                     		: 500
'Before Save Document                   : BeforeDocSave           			: 700
'After Save Document               		: AfterDocSave               		: 800
'Any Model Parameter Change        		: AfterAnyParamChange   			: 1000
'Part Geometry Change**            		: PartBodyChanged         			: 1200
'Material Change**                  	: AfterMaterialChange     			: 1400
'Drawing View Change***               	: AfterDrawingViewsUpdate  			: 1500
'iProperty(Change)                  	: AfterAnyiPropertyChange           : 1600
'Feature Suppression Change**          	: AfterFeatureSuppressionChange   	: 2000
'Component Suppression Change*   		: AfterComponentSuppressionChange 	: 2200
'iPart / iAssembly Change Component* 	: AfterComponentReplace   			: 2400
'New Document                         	: AfterDocNew                  		: 2600
InventorVb.DocumentUpdate()
End Sub
Function GetiLogicEventPropSet(cDocument As Document) As Inventor.PropertySet
	On Error Resume Next
		iLogicEventPropSet = cDocument.PropertySets.Item("iLogicEventsRules")
		If iLogicEventPropSet Is Nothing Then
			iLogicEventPropSet = cDocument.PropertySets.Item("_iLogicEventsRules")
		If iLogicEventPropSet.InternalName <> "{2C540830-0723-455E-A8E2-891722EB4C3E}" Then
			Call iLogicEventPropSet.Delete
			iLogicEventPropSet = cDocument.PropertySets.Add("iLogicEventsRules", "{2C540830-0723-455E-A8E2-891722EB4C3E}")
			MsgBox ("Unable to create the Event Triggers property for this file!", , "Event Triggers Not Set")
			Err.Raise(1)
			Exit Function
	On Error GoTo 0
	Return iLogicEventPropSet
End Function
I hope this helps with your problem. Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Sergio.D.Suárez
note that a function is added to add the events you need (you can remove this fragment if you do not need it)
Mechanical Designer
vkulikajevas
Thank you for fast reply, Sergio D. Suarez.
I have tried running this Rule multiple times, and it doesn't seem to do anything. It Doesn't show any error though.
Curtis_Waguespack
Hi vkulikajevas ,
Make sure your file is a part file and has a volume (meaning you have at least one solid feature).
I hope this helps.
Curtis
