External Rule executed for all components in the assembly
vkulikajevas
Message 1 of 22
vkulikajevas
Can you help me write a code Ilogic Rule, that can access external rule for every body in the assembly?
External_XYZ_Rule writes extents of the part by X,Y,Z.
I need it to be executed automatically for all the Assembly parts, that Solid1, Solid2, Solid3 would have their extent parameters written in the custom parameters.
See files attached:
Replies (21)
Message 21 of 22
vkulikajevas
@Anonymous wrote:
I tried to apply your rule and it works perfectly fine for all sub assemblies. Thank you very much for this. But can this also apply to ipt files under the sub assemblies? We actually have some properties that we added to our illogic form and want it to run in all ipt files also so it can take the basic brand name, etc. is it possible to run this rule so those properties also apply to the ipt files besides just the sub assemblies? thanks in advance
I have corrected the code, It should work in all subassemblies now as well. Cheers!
Sub Bounding_Box_Main()
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.ActiveDocument
    Call Bounding_Box(oAsmDoc.ComponentDefinition.Occurrences, 1)
  End Sub
  Sub Bounding_Box(Occurrences As ComponentOccurrences, _
                             Level As Integer)
    ' Iterate through all of the occurrence in this collection.  This
    ' represents the occurrences at the top level of an assembly.
    Dim oOcc As ComponentOccurrence
    Dim oCustomPropSet As PropertySet
    Dim modX As Double
    Dim modY As Double
    Dim modZ As Double
    Dim Ilgis As Double
    Dim Plotis As Double
    Dim Storis As Double
    Dim DIMALL As String
    For Each oOcc In Occurrences
     'If it is an Assembly go to next Level
    Set oCustomPropSet = oOcc.Definition.Document.PropertySets.Item(4)
     If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
      Call Bounding_Box(oOcc.SubOccurrences, Level + 1)
     ElseIf oOcc.DefinitionDocumentType = kPartDocumentObject Then
     Debug.Print Space(Level * 3) & oOcc.Name
'Get the UserDefinedPropertySet
         ' For X
         'If CheckPropertyExists(oCustomPropSet, "ModX") Then
          'oCustomPropSet.Item("ModX").Expression = modXr
         'Else
         ' Call oCustomPropSet.Add(modXr, "ModX")
         'End If
         ' For Y
         'If CheckPropertyExists(oCustomPropSet, "ModY") Then
          'oCustomPropSet.Item("ModY").Expression = modYr
         'Else
          'Call oCustomPropSet.Add(modYr, "ModY")
         'End If
        ' For Z
          'If CheckPropertyExists(oCustomPropSet, "ModZ") Then
          'oCustomPropSet.Item("ModZ").Expression = modZr
         'Else
          'Call oCustomPropSet.Add(modZr, "ModZ")
         'End If
           'Get the ranges Model X, Model Y, Model Z
         modX = (oOcc.RangeBox.MaxPoint.X + (oOcc.RangeBox.MinPoint.X) * -1) * 10
         modY = (oOcc.RangeBox.MaxPoint.Y + (oOcc.RangeBox.MinPoint.Y) * -1) * 10
         modZ = (oOcc.RangeBox.MaxPoint.Z + (oOcc.RangeBox.MinPoint.Z) * -1) * 10
         'Round to 0
         modXr = Round(modX, 0)
         modYr = Round(modY, 0)
         modZr = Round(modZ, 0)
'Create L x W x H
If modXr >= modYr And modYr >= modZr Then
Ilgis = modXr
Plotis = modYr
Storis = modZr
ElseIf modXr >= modZr And modZr >= modYr Then
Ilgis = modXr
Plotis = modZr
Storis = modYr
ElseIf modYr >= modZr And modZr >= modXr Then
Ilgis = modYr
Plotis = modZr
Storis = modXr
ElseIf modYr > modXr And modXr > modZr Then
Ilgis = modYr
Plotis = modXr
Storis = modZr
ElseIf modZr > modXr And modXr > modYr Then
Ilgis = modZr
Plotis = modXr
Storis = modYr
ElseIf modZr > modYr And modYr > modXr Then
Ilgis = modZr
Plotis = modYr
Storis = modXr
 sq_m = Ilgis * Plotis * 0.000001
 sq_m = Round(sq_m, 3)
 DIMALL = Ilgis & "x" & Plotis & "x" & Storis
'Check -> Create/Overwrite Custom Parameter.
If CheckPropertyExists(oCustomPropSet, "DIMALL") Then
 oCustomPropSet.Item("DIMALL").Expression = DIMALL
Else
Call oCustomPropSet.Add(DIMALL, "DIMALL")
If CheckPropertyExists(oCustomPropSet, "Ilgis") Then
 oCustomPropSet.Item("Ilgis").Expression = Ilgis
Else
Call oCustomPropSet.Add(Ilgis, "Ilgis")
If CheckPropertyExists(oCustomPropSet, "Plotis") Then
 oCustomPropSet.Item("Plotis").Expression = Plotis
Else
Call oCustomPropSet.Add(Plotis, "Plotis")
If CheckPropertyExists(oCustomPropSet, "Storis") Then
 oCustomPropSet.Item("Storis").Expression = Storis
Else
Call oCustomPropSet.Add(Storis, "Storis")
If CheckPropertyExists(oCustomPropSet, "sq_m") Then
 oCustomPropSet.Item("sq_m").Expression = sq_m
Else
Call oCustomPropSet.Add(sq_m, "sq_m")
     Next
End Sub
Public Function CheckPropertyExists(oProps As PropertySet, oPropName As String) As Boolean
 CheckPropertyExists = False
 Dim oProp As Property
 For Each oProp In oProps
    If oProp.Name = oPropName Then
        CheckPropertyExists = True
 Next
End Function
Message 22 of 22
thank you so much for this. sorry for the later reply. shall try this and let you know how it works with our parts and assemblies. Appreciate your help. many thanks once again
