Expression to group components?
ndamgaard
ndamgaard
In Ilogic rules, is it possible to create and expression that groups a selection of components, so that all these components can be referenced with one expression (e.g. Component.Isactive(group)=True or False)?
To give an idea of what I am trying t
component_group
=List("Assembly1", "Assembly2", "Assembly3", "Assembly4",..., "Assembly99")
If statement1=True Then Component.IsActive(component_group)=True If statement1=False Then
Component.IsActive(component_group)=False EndIf --------
I hope it is apparent what I am trying to achieve. Otherwise, let me know.
theo.bot
You can use this idea, but you need to add a loop in you code to suppress each component. Here's a small sample:
Dim MyGroup = New String(){"P144-00030:1", "P144-00029:2","P133-00210:1"}
For Each oVal In MyGroup
		Component.IsActive(oVal) = False
Next
ndamgaard
Thanks for the response.
It works!
ndamgaard
Hello Theo,
A follow up question: Can I reference MyGroup in another rule?
I wish to keep my categories in its own rule, if possible.
theo.bot
In your main rule you can create a SharedVariable. In other rules you can use this sharedVariable.
so rule1:
SharedVariable("MyGroup") = MyGroup
Rule2:
For Each oVal In SharedVariable("MyGroup")
Next
