Exportparameter for JT in Pyton
Hello.
I've coded a Python script to export a list of assemblies as JT files. It works fine.
The export command is, after defining the outputfilename
oDoc.SaveAs(OUTPUT_PATH, True)
The problem is that it create a JT file in version 7.0 and only monolitic.
From the VBA Version I found the possibility to pass options to the SaveCopyAs command.
oContext = invApp.TransientObjects.CreateTranslationContext()
oOptions = invApp.TransientObjects.CreateNameValueMap()
oOptions = oDoc.SaveCopyAs(oDoc, oContext, oOptions, OUTPUT_PATH)
My problem are first the SaveCopyAs command seems not working through win32com.
Second I didn't figure out how to pass the options (as list, as dictionary). That's probably the reason why it doesn't work.
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that solution in below forum discussion would be helpful.
https://forums.autodesk.com/t5/inventor-customization/converting-vba-script-into-python-comtypes-script/m-p/7518372
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Thank you @chandra.shekar.g
I found the discussion before I've posted my question. It didn't help. If I copy&paste the script it doesn't work. It can't create the options value map. So when printing it I get the error.
Exception has occurred: AttributeError
CreateNameValueMap.Set
File "X:\programmier\python\inventor\step.py", line 43, in <module> print(Options.Set)
That's why I asked this question.
