Message 1 of 1
Exporting only solid bodies as STEP file using API
I am trying to export only solid bodies from a part file into a STEP file using API. But as my file consists of sketches and surfaces along with solids, even the sketches and surfaces are exported along with the solid bodies. Is there anyway to export only the solid, and filter any sketches or surfaces? Thank you.
This is the code that I am using, which is directly copied from the samples.
Public Sub ExportToSTEP()
' Get the STEP translator Add-In.
Dim oSTEPTranslator As TranslatorAddIn
Set oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
If oSTEPTranslator Is Nothing Then
MsgBox "Could not access STEP translator."
Exit Sub
Dim oContext As TranslationContext
Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
oOptions.Value("ApplicationProtocolType") = 2
oContext.Type = kFileBrowseIOMechanism
Dim oData As DataMedium
Set oData = ThisApplication.TransientObjects.CreateDataMedium
oData.FileName = "C:\temptest.stp"
Call oSTEPTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End Sub |
