Exporting IGS and STEP
taher.basha
taher.basha
I am trying to export a model to IGS and STEP. when the model is exported, there is a dialogue box immediately appreas saying that "unable to open the file" as shown in pic down.
Is Inventor trying to open the exported file immediately? if yes. then how to suppress the opening of igs and step
Public Sub ExportToIGES()
    ' Get the IGES translator Add-In.
    Dim oIGESTranslator As TranslatorAddIn
    Set oIGESTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F44-0C01-11D5-8E83-0010B541CD80}")
    If oIGESTranslator Is Nothing Then
        MsgBox "Could not access IGES translator."
        Exit Sub
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    If oIGESTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
        ' Set geometry type for wireframe.
        ' 0 = Surfaces, 1 = Solids, 2 = Wireframe
        oOptions.Value("GeometryType") = 1
        ' To set other translator values:
        ' oOptions.Value("SolidFaceType") = n
        ' 0 = NURBS, 1 = Analytic
        ' oOptions.Value("SurfaceType") = n
        ' 0 = 143(Bounded), 1 = 144(Trimmed)
        oContext.Type = kFileBrowseIOMechanism
        Dim oData As DataMedium
        Set oData = ThisApplication.TransientObjects.CreateDataMedium
        oData.FileName = "C:\Temptest.igs"
        Call oIGESTranslator.SaveCopyAs(ThisApplication.ActiveDocument, oContext, oOptions, oData)
End Sub
JelteDeJong
I translated your code to vb.net/ilogic code and it works without any issues. (Plz, be aware that VBA is obsolete. Have a look at this blog post "Is VBA in Inventor obsolete?".) it looks like this. I found 1 problem that could be the problem. The file name in your example code is in the c root. I expect that you wanted to save your file in the temp folder but made a typo.
Dim oIGESTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F44-0C01-11D5-8E83-0010B541CD80}")
    MsgBox("Could not access IGES translator.")
    Exit Sub
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
    Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
    oData.FileName = "C:\Temp\test.igs"
Jelte de Jong
Blog: hjalte.nl - github.com
taher.basha
I changed the saving address, and the saving address changes all time with change in model.
anything has to do with this line of code "oIGESTranslator.HasOpenOptions"
which can stop opening the model immediately
vpeuvion
The problem is probably that you are trying to write to the root of C: and you do not have permission.
Vincent.
JelteDeJong
You could try to check your file names before you try to export. you could use a method like this:
	Public Sub Main()
        MsgBox(hasWriteAccessToFolder("C:\Temp\test.igs"))
    End Sub
    Private Function hasWriteAccessToFolder(folderPath) As Boolean
        Try
            Dim ds As System.Security.AccessControl.DirectorySecurity = System.IO.Directory.GetAccessControl(folderPath)
            Return True
        Catch ex As Exception
            Return False
        End Try
    End Function
Jelte de Jong
taher.basha
For sure! I will use this solution
