Exporting DXF and PDF
Howdy yall,
I have some code (shown below) that, upon save, prompts if I want to export to DXF, and if so, either saves it in a specific place (if the drawing file name meets certain criteria) or in the same directory the drawing is in (if the drawing name does NOT meet specific criteria). I would like to expand this code to cover a little more. Basically, if we have a picture in the drawing, the DXF doesn't include the picture (the nature of a DXF), so I want to use some code (that I found in another post) to check if a picture exists on any sheet, and if so, do the normal DXF export, and ALSO, export all sheets to a PDF. Can anyone point me in the right direction to do this? I haven't done VB in years and when I tried to do this myself, I kept getting all sorts of errors or it just not working. Thanks!
'query user
question = MessageBox.Show("is a .DXF Export Required?" & vbNewLine & "WARNING: This operation will overwrite existing DXF files!", "Export to DXF",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
          'set condition based on answer
            If question = vbYes Then
'Bunch of code here to test the file name and set strPath'
Else
	strPath = ThisDoc.PathAndFileName(False)
'	Dim strFolder As String
	strFolder = Left(strPath, Len(strPath)-Len(iProperties.Value("Project", "Part Number")))
' Get the DXF and PDF translator Add-Ins.
Dim DXFAddIn As TranslatorAddIn
'Dim PDFAddIn As TranslatorAddIn
DXFAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC4-122E-11D5-8E91-0010B541CD80}")
'PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
'Set a reference to the active document (the document to be published).
Dim oDocument As Document
oDocument = ThisApplication.ActiveDocument
Dim oContext As TranslationContext
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
' Create a NameValueMap object
Dim oOptions As NameValueMap
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
' Create a DataMedium object
Dim oDataMedium As DataMedium
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
' Sets directory for file save
Dim DXFDirectory As String
DXFDirectory = strFolder
' Sets save name as iProperties value
Dim SaveName As String
SaveName = iProperties.Value("Project", "Part Number")
' Check whether the translator has 'SaveCopyAs' options
If DXFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
Dim strIniFile As String
strIniFile = "\\server\Company Engineering Documents\Inventor 2013 Files\Save Templates\DXF Export.ini"
' Create the name-value that specifies the ini file to use.
oOptions.Value("Export_Acad_IniFile") = strIniFile
'Set the destination file name
oDataMedium.FileName = ThisDoc.PathAndFileName(False)
oDataMedium.FileName = DXFDirectory & SaveName & ".dxf"
If ThisDoc.Document.Sheets.Count > 1 Then
	For sheet_count = 1 To ThisDoc.Document.Sheets.Count
		If Len(Dir(DXFDirectory & SaveName & "_SHEET_" & sheet_count & ".dxf")) <> 0 Then
			Kill(DXFDirectory & SaveName & "_SHEET_" & sheet_count & ".dxf")
		Else If Len(Dir(DXFDirectory & SaveName & ".dxf")) <> 0 Then
			Kill(DXFDirectory & SaveName & ".dxf")
	Next sheet_count
'Publish document.
DXFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'Launch the dxf file in whatever application Windows is set to open this document type with
'i = MessageBox.Show("Preview the DXF file? " & SaveName & " " & strFolder, "DXF Preview",MessageBoxButtons.YesNo,MessageBoxIcon.Question)
'If i = vbYes Then ThisDoc.Launch(oDataMedium.FileName)
Anyone at all? I had previously loaded the PDF plugin at the same place as the DXF plugin and basically tried to insert various lines where the DXF ones are as well but I feel like the options won't be the same
Anyone?
