exporting bom into csv fil
GosponZ
GosponZ
Exporting bom as csv file is not problem, but problem is that leading zero is removed and each time need format column and add 0. Is it there easy way anybody know? Please asap. Thank you all
Alexrose1942
can you attach a CSV for example?
GosponZ
Not much to attach. My part number is 011111 and after save  bom to csv file part number become 11111. Zero number is eaten. Is it there ilogic rule anybody is using for exporting bom and format column into text, i would greatly appreciated if is shared.
frederic.vandenplas
I would suggest to modify your excel template so when you time a zero, zero remains. Just use standard or text
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
