Export to STP
Export to STP
donnie.morris
Export to STP
donnie.morris
I have located two pieces of code that I need to merge into one if anyone is willing to provide some assistance.
I am trying to Export to a ".stp" from an ".idw" but I need the user to be able to choose the location of the exported file.
The code I have found exports to .stp perfectly but to a defined location, in this case "C:\TEMP" , I need it to follow the location as defined by a piece of code meant to export to a .pdf
 Is there anyway to merge the .pdf location portion to the .stp file type code?
Here's the two pieces of code:
.pdf location
' Get current location of this file
Dim ExportPath As String = ThisDoc.Path
' Check that this file has been saved and actually exists on disk
If String.IsNullOrEmpty(ExportPath) Then
    MsgBox("This file has not yet been saved and doesn't exist on disk!" _
	& vbLf & "Please save it first",64, "Lord iLogic")
Return
' Define folder browse dialog
Dim Dialog = New FolderBrowserDialog()
' Set options for folder browser dialog
Dialog.SelectedPath = ExportPath
Dialog.ShowNewFolderButton = True
Dialog.Description = "Choose Folder for Export..."
' Show dialog box
If DialogResult.OK = Dialog.ShowDialog() Then
    ' User clicked 'ok' on dialog box - capture the export path
    ExportPath = Dialog.SelectedPath & "\"
Else
    ' User clicked 'cancel' on dialog box - exit
    Return
oFileName = iProperties.Value("Custom", "Drawing Number")
' Define the filename of the file to be exported
' In this Case it Is a PDF file extension
ExportFilename = oFileName & ".pdf"
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
'set PDF Options
oOptions.Value("All_Color_AS_Black") = 1
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets
'Set the PDF target file name
oDataMedium.FileName = ExportPath & ExportFilename
Try
	'Publish document
	oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
Catch
	MessageBox.Show("Error writing out PDF", "iLogic")
	bError = True
End Try
If bError <> True Then
	'Ask user If they want To open (launch) the file we just exported...
	oMessage = "File exported: " & _
			ExportPath & ExportFilename & vbLf & vbLf & _
			"Do you want to open the PDF Now?"
	oQuestion = MessageBox.Show(oMessage, _
	"Formsprag iLogic - File Exported",MessageBoxButtons.YesNo)
	If oQuestion = vbYes Then
		ThisDoc.Launch(ExportPath & ExportFilename)
.stp code
'Dim statement: Declares and allocates storage space for variables
Dim oPart As Inventor.PartDocument
'Takes the part shown in the 1st view
'of the current sheet's DrawingViews collection
oDrawingDoc = ThisDrawing.Document
oSheet = ActiveSheet.Sheet
oDrawingView = oSheet.DrawingViews.Item(1)
oPart = ActiveSheet.View(oDrawingView.Name).ModelDocument
' Get the STEP translator Add-In.
	Dim oSTEPTranslator As TranslatorAddIn
	oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	Dim oContext As TranslationContext
	Dim oOptions As NameValueMap
	oStepFileName = iProperties.Value("Project", "Part Number") & " " & iProperties.Value("Project", "Description")
If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
		    ' Set application protocol.
		    ' 2 = AP 203 - Configuration Controlled Design
		    ' 3 = AP 214 - Automotive Design
    oOptions.Value("ApplicationProtocolType") = 3
		    ' Other options...
		    'oOptions.Value("Author") = ""
		    'oOptions.Value("Authorization") = ""
		    'oOptions.Value("Description") = ""
		    'oOptions.Value("Organization") = ""
    Dim oData As DataMedium
    oData = ThisApplication.TransientObjects.CreateDataMedium
		strFolder = "C:\TEMP\"
   		oData.FileName = strFolder & "\" & oStepFileName & ".stp"
	oSTEPTranslator.SaveCopyAs(oPart, oContext, oOptions, oData)
JelteDeJong
Does this work for you:
Dim doc As DrawingDocument = ThisDoc.Document
Dim sheet As Sheet = doc.ActiveSheet
Dim view As DrawingView = sheet.DrawingViews.Item(1)
Dim partDoc As PartDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
	& vbLf & "Please save it first", 64, "Lord iLogic")
	Return
Dim drawingNumber = iProperties.Value("Custom", "Drawing Number")
Dim dialog As Inventor.FileDialog
ThisApplication.CreateFileDialog(dialog)
dialog.InitialDirectory = ExportPath
dialog.FileName = drawingNumber
dialog.DialogTitle = "Save"
dialog.Filter = "Step files(*.stp)|*.stp|All Files (*.*)|*.*"
dialog.CancelError = True
Try
	dialog.ShowSave()
Catch ex As Exception
	Return
End Try
Dim oSTEPTranslator As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
If oSTEPTranslator.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then
	' Other options...
	Dim oData As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	oData.FileName = dialog.FileName
	oSTEPTranslator.SaveCopyAs(partDoc, oContext, oOptions, oData)
Jelte de Jong
Blog: hjalte.nl - github.com
donnie.morris
Perfect,
Thanks!
donnie.morris
Can this code create both a .stp and . pdf at the same time?
