Export to STEP with CHATGPT
Ivan_Sinicyn
Message 1 of 1
Ivan_Sinicyn
I don't know any programming language. I have tried several times to familiarize myself with vbnet, but I don't have enough time for all that. I very often export files to step format with different settings. Each time, exporting one file at a time was just tiring. I tried to find an off-the-shelf solution, but didn't find one. I tried several times to use large language models such as CHATGPT. Before version 4.0, it required basic programming knowledge for edits after code generation, but yesterday I tried version 4o and was shocked. CHATGPT wrote valid code from the beginning, taking into account only my requests. When the code grew up to 200 lines, the first errors and difficulties started. Sometimes I would just dump the log and CHATGPT would fix the errors in the new version by itself. Sometimes I found similar problems on forums or API reference and fed them into the CHATGPT window. The problems were solved again. Now there are about 700 lines of code in the script that closes all my requests. I spent about 12 hours on this, half of which was spent generating the script from the beginning. Since I don't know how to edit code manually, I asked CHATGPT to generate it from the beginning each time with all edits.
I am attaching the ILogic code to the post. It may be useful for someone.
The script settings are saved in c:\Users\%CURRENTUSER%\AppData\Roaming\FSTEPExport\ folder.
The folder and settings file are created the first time you press the SAVE button.
Imports Inventor
Imports System.IO
Imports System.Windows.Forms
Public Class PathInputForm
    Inherits System.Windows.Forms.Form
    Public Property OutputPath As String
    Public Property OverwriteFiles As Boolean
    Public Property DistributeByMaterial As Boolean
    Public Property IncludeQuantity As Boolean ' New property for checkbox
    Public Property FilterSheetMetal As Boolean ' New property for checkbox
    Private textBox As System.Windows.Forms.TextBox
    Private buttonOK As System.Windows.Forms.Button
    Private buttonCancel As System.Windows.Forms.Button
    Private buttonAuto As System.Windows.Forms.Button
    Private buttonDefault As System.Windows.Forms.Button
    Private buttonBrowse As System.Windows.Forms.Button
    Private buttonSavePath As System.Windows.Forms.Button ' New button to save path
    Private buttonClear As System.Windows.Forms.Button ' New button to clear folder
    Private buttonSaveSettings As System.Windows.Forms.Button ' New button to save settings
    Private checkBoxOverwrite As System.Windows.Forms.CheckBox
    Private checkBoxDistribute As System.Windows.Forms.CheckBox
    Private checkBoxIncludeQuantity As System.Windows.Forms.CheckBox ' New checkbox
    Private checkBoxFilterSheetMetal As System.Windows.Forms.CheckBox ' New checkbox
    Private groupBoxPath As System.Windows.Forms.GroupBox
    Private assemblyFolderPath As String
    Private toolTip As System.Windows.Forms.ToolTip
    Private settingsManager As settingsManager
    Public Sub New(assemblyFolderPath As String)
        Me.assemblyFolderPath = assemblyFolderPath
        Me.Text = "FSTEPExport"
        Me.Width = 450
        Me.Height = 400 ' Increase height to accommodate new elements
        Me.StartPosition = FormStartPosition.CenterScreen ' Center the window on the screen
        toolTip = New System.Windows.Forms.ToolTip()
        settingsManager = New SettingsManager("settings.txt")
        groupBoxPath = New System.Windows.Forms.GroupBox()
        groupBoxPath.Text = "Save Path"
        groupBoxPath.Width = 400
        groupBoxPath.Height = 120
        groupBoxPath.Top = 10
        groupBoxPath.Left = 20
        textBox = New System.Windows.Forms.TextBox()
        textBox.Width = 370
        textBox.Top = 20
        textBox.Left = 10
        textBox.Text = settingsManager.LoadDefaultPath() ' Load default path
        buttonAuto = New System.Windows.Forms.Button()
        buttonAuto.Text = "Auto"
        buttonAuto.Top = 50
        buttonAuto.Left = 10
        buttonAuto.Width = 120
        AddHandler buttonAuto.Click, Sub(sender, e)
                                         If Not String.IsNullOrEmpty(assemblyFolderPath) Then
                                             textBox.Text = System.IO.Path.Combine(assemblyFolderPath, "STEP")
                                         Else
                                             MessageBox.Show("assemblyFolderPath is not initialized.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
                                     End Sub
        toolTip.SetToolTip(buttonAuto, "The path is set according to the assembly location.")
        buttonDefault = New System.Windows.Forms.Button()
        buttonDefault.Text = "Default"
        buttonDefault.Top = 50
        buttonDefault.Left = 140
        buttonDefault.Width = 120
        AddHandler buttonDefault.Click, Sub(sender, e)
                                        End Sub
        toolTip.SetToolTip(buttonDefault, "The path is set according to the data recorded in the file.")
        buttonSavePath = New System.Windows.Forms.Button() ' New button to save path
        buttonSavePath.Text = "*"
        buttonSavePath.Top = 50
        buttonSavePath.Left = 270
        buttonSavePath.Width = 40
        AddHandler buttonSavePath.Click, AddressOf Me.ButtonSavePath_Click
        toolTip.SetToolTip(buttonSavePath, "Save path for 'Default' button")
        buttonBrowse = New System.Windows.Forms.Button()
        buttonBrowse.Text = "Browse..."
        buttonBrowse.Top = 50
        buttonBrowse.Left = 320
        buttonBrowse.Width = 60
        AddHandler buttonBrowse.Click, AddressOf Me.ButtonBrowse_Click
        toolTip.SetToolTip(buttonBrowse, "Select another export folder.")
        groupBoxPath.Controls.Add(textBox)
        groupBoxPath.Controls.Add(buttonAuto)
        groupBoxPath.Controls.Add(buttonDefault)
        groupBoxPath.Controls.Add(buttonSavePath)
        groupBoxPath.Controls.Add(buttonBrowse)
        checkBoxOverwrite = New System.Windows.Forms.CheckBox()
        checkBoxOverwrite.Text = "Overwrite existing files"
        checkBoxOverwrite.Top = 140
        checkBoxOverwrite.Left = 20
        checkBoxOverwrite.Width = 400
        checkBoxOverwrite.Checked = True ' Set checkbox to be checked by default
        checkBoxDistribute = New System.Windows.Forms.CheckBox()
        checkBoxDistribute.Text = "Distribute by material"
        checkBoxDistribute.Top = 170
        checkBoxDistribute.Left = 20
        checkBoxDistribute.Width = 400
        checkBoxIncludeQuantity = New System.Windows.Forms.CheckBox() ' New checkbox
        checkBoxIncludeQuantity.Text = "Include quantity in export file"
        checkBoxIncludeQuantity.Top = 200
        checkBoxIncludeQuantity.Left = 20
        checkBoxIncludeQuantity.Width = 400
        checkBoxIncludeQuantity.AutoSize = True ' Ensure the text is in one line
        checkBoxIncludeQuantity.Checked = True ' Set checkbox to be checked by default
        checkBoxFilterSheetMetal = New System.Windows.Forms.CheckBox() ' New checkbox
        checkBoxFilterSheetMetal.Text = "Exclude sheet metal"
        checkBoxFilterSheetMetal.Top = 230
        checkBoxFilterSheetMetal.Left = 20
        checkBoxFilterSheetMetal.Width = 400
        checkBoxFilterSheetMetal.AutoSize = True ' Ensure the text is in one line
        checkBoxFilterSheetMetal.Checked = True ' Set checkbox to be checked by default
        buttonClear = New System.Windows.Forms.Button() ' New button to clear folder
        buttonClear.Text = "Clear folder"
        buttonClear.Top = 260
        buttonClear.Left = 20
        buttonClear.Width = 120
        AddHandler buttonClear.Click, AddressOf Me.ButtonClear_Click
        toolTip.SetToolTip(buttonClear, "Delete all files in the destination folder")
        buttonSaveSettings = New System.Windows.Forms.Button() ' New button to save settings
        buttonSaveSettings.Text = "Save"
        buttonSaveSettings.Top = 260
        buttonSaveSettings.Left = 150
        buttonSaveSettings.Width = 120
        AddHandler buttonSaveSettings.Click, AddressOf Me.ButtonSaveSettings_Click
        toolTip.SetToolTip(buttonSaveSettings, "Save checkbox settings")
        buttonOK = New System.Windows.Forms.Button()
        buttonOK.Text = "Export"
        buttonOK.Top = 290
        buttonOK.Left = 280
        buttonOK.Width = 120
        AddHandler buttonOK.Click, AddressOf Me.ButtonOK_Click
        buttonCancel = New System.Windows.Forms.Button()
        buttonCancel.Text = "Cancel"
        buttonCancel.Top = 290
        buttonCancel.Left = 150
        buttonCancel.Width = 120
        AddHandler buttonCancel.Click, AddressOf Me.ButtonCancel_Click
        Me.Controls.Add(groupBoxPath)
        Me.Controls.Add(buttonOK)
        Me.Controls.Add(buttonCancel)
        Me.Controls.Add(checkBoxOverwrite)
        Me.Controls.Add(checkBoxDistribute)
        Me.Controls.Add(checkBoxIncludeQuantity) ' Add checkbox to form
        Me.Controls.Add(checkBoxFilterSheetMetal) ' Add checkbox to form
        Me.Controls.Add(buttonClear) ' Add button to form
        Me.Controls.Add(buttonSaveSettings) ' Add button to form
        LoadSettings()
    End Sub
    Private Sub ButtonSavePath_Click(sender As Object, e As EventArgs)
        settingsManager.SaveDefaultPath(textBox.Text)
        MessageBox.Show("Default path saved.", "Information", MessageBoxButtons.OK, MessageBoxIcon.Information)
    End Sub
    Private Sub ButtonClear_Click(sender As Object, e As EventArgs)
        If MessageBox.Show("Are you sure you want to delete all files in the destination folder?", "Confirmation", MessageBoxButtons.YesNo, MessageBoxIcon.Question) = DialogResult.Yes Then
            Try
                For Each file As String In System.IO.Directory.GetFiles(textBox.Text)
                    System.IO.File.Delete(File)
                Next
                For Each dir As String In System.IO.Directory.GetDirectories(textBox.Text)
                    System.IO.Directory.Delete(Dir, True)
                Next
                MessageBox.Show("Destination folder cleared.", "Information", MessageBoxButtons.OK, MessageBoxIcon.Information)
            Catch ex As Exception
                MessageBox.Show("Error clearing destination folder: " & ex.Message, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            End Try
    End Sub
    Private Sub ButtonSaveSettings_Click(sender As Object, e As EventArgs)
        SaveSettings()
        MessageBox.Show("Settings saved.", "Information", MessageBoxButtons.OK, MessageBoxIcon.Information)
    End Sub
    Private Sub ButtonOK_Click(sender As Object, e As EventArgs)
        SaveSettings()
        Me.OutputPath = textBox.Text
        Me.OverwriteFiles = checkBoxOverwrite.Checked
        Me.DistributeByMaterial = checkBoxDistribute.Checked
        Me.IncludeQuantity = checkBoxIncludeQuantity.Checked ' Save checkbox state
        Me.FilterSheetMetal = checkBoxFilterSheetMetal.Checked ' Save checkbox state
        Me.DialogResult = System.Windows.Forms.DialogResult.OK
        Me.Close()
    End Sub
    Private Sub ButtonCancel_Click(sender As Object, e As EventArgs)
        Me.DialogResult = System.Windows.Forms.DialogResult.Cancel
        Me.Close()
    End Sub
    Private Sub ButtonBrowse_Click(sender As Object, e As EventArgs)
        Using folderBrowser As New FolderBrowserDialog()
            folderBrowser.Description = "Select a folder to save .step files"
            folderBrowser.SelectedPath = assemblyFolderPath ' Set initial folder
            If folderBrowser.ShowDialog() = DialogResult.OK Then
                textBox.Text = folderBrowser.SelectedPath
        End Using
    End Sub
    Private Sub SaveSettings()
        settingsManager.SaveCheckBoxState(checkBoxOverwrite, "OverwriteFiles")
        settingsManager.SaveCheckBoxState(checkBoxDistribute, "DistributeByMaterial")
        settingsManager.SaveCheckBoxState(checkBoxIncludeQuantity, "IncludeQuantity")
        settingsManager.SaveCheckBoxState(checkBoxFilterSheetMetal, "FilterSheetMetal")
    End Sub
    Private Sub LoadSettings()
        settingsManager.LoadCheckBoxState(checkBoxOverwrite, "OverwriteFiles")
        settingsManager.LoadCheckBoxState(checkBoxDistribute, "DistributeByMaterial")
        settingsManager.LoadCheckBoxState(checkBoxIncludeQuantity, "IncludeQuantity")
        settingsManager.LoadCheckBoxState(checkBoxFilterSheetMetal, "FilterSheetMetal")
    End Sub
End Class
Public Class SettingsManager
    Private settingsFilePath As String
    ' Constructor accepts the settings file name
    Public Sub New(settingsFileName As String)
        Dim settingsFolder As String = System.IO.Path.Combine(System.Environment.GetFolderPath(System.Environment.SpecialFolder.ApplicationData), "FSTEPExport")
        If Not System.IO.Directory.Exists(settingsFolder) Then
            System.IO.Directory.CreateDirectory(settingsFolder)
        settingsFilePath = System.IO.Path.Combine(settingsFolder, settingsFileName)
    End Sub
    ' Method to save the state of checkboxes
    Public Sub SaveCheckBoxState(checkBox As CheckBox, id As String)
        Dim settings As New List(Of String)
        If System.IO.File.Exists(settingsFilePath) Then
            settings.AddRange(System.IO.File.ReadAllLines(settingsFilePath))
        Dim index As Integer = settings.FindIndex(Function(line) line.StartsWith(id & "="))
        Dim newLine As String = id & "=" & checkBox.Checked.ToString() & " ' " & checkBox.Text
        If index >= 0 Then
            settings(index) = newLine
        Else
            settings.Add(newLine)
        System.IO.File.WriteAllLines(settingsFilePath, settings)
    End Sub
    ' Method to load the state of checkboxes
    Public Sub LoadCheckBoxState(checkBox As CheckBox, id As String)
            Dim settings As String() = System.IO.File.ReadAllLines(settingsFilePath)
            For Each setting As String In settings
                If setting.StartsWith(id & "=") Then
                    Dim value As String = setting.Split("="c)(1).Split("'"c)(0).Trim()
                    Boolean.TryParse(value, checkBox.Checked)
            Next
        Else
            checkBox.Checked = True ' Set default value if file does not exist
    End Sub
    ' Method to save the default path
    Public Sub SaveDefaultPath(path As String)
        Dim index As Integer = settings.FindIndex(Function(line) line.StartsWith("DefaultPath="))
        Dim newLine As String = "DefaultPath=" & path & " ' Default path"
        If index >= 0 Then
        Else
    End Sub
    ' Method to load the default path
    Public Function LoadDefaultPath() As String
                If setting.StartsWith("DefaultPath=") Then
                    Return setting.Split("="c)(1).Split("'"c)(0).Trim()
            Next
        Return "C:\DXF" ' Default value if file does not exist
    End Function
End Class
Sub Main()
    ' Get the active document
    Dim invApp As Inventor.Application = ThisApplication
    Dim activeDoc As Document = invApp.ActiveDocument
    ' Check if the document is an assembly
    If activeDoc.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
        System.Windows.Forms.MessageBox.Show("Open an assembly file to run this script.")
        Return
    ' Check current selection priority
    If activeDoc.SelectionPriority <> 67591 Then
        ' If selection priority is different from part selection, show a warning and change priority
        MsgBox("Selection mode is different from part selection. The mode will be changed. Please reselect the parts and try again.", vbExclamation + vbOKOnly, "Warning")
        activeDoc.SelectionPriority = 67591
        ' Deselect all selected components
        Dim oSelectSet As SelectSet
        oSelectSet = activeDoc.SelectSet
        oSelectSet.Clear()
        Return
    ' Get the assembly document
    Dim asmDoc As AssemblyDocument = activeDoc
    Dim asmCompDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
    ' Get all selected components in the assembly
    Dim selectedObjects As ObjectCollection = invApp.TransientObjects.CreateObjectCollection()
    For Each obj In invApp.ActiveDocument.SelectSet
        If TypeOf obj Is ComponentOccurrence Then
            selectedObjects.Add(obj)
    Next
    ' If no components are selected, display a message and end the script
    If selectedObjects.Count = 0 Then
        System.Windows.Forms.MessageBox.Show("Select parts for export and try again.")
        Return
    ' Create a dictionary to store unique part numbers and materials
    Dim uniqueParts As New HashSet(Of String)
    Dim materialDict As New Dictionary(Of String, String)
    ' Create a dictionary to store the number of occurrences of each part
    Dim partDict As New Dictionary(Of String, Integer)
    ' Show the form to enter the path
    Dim form As New PathInputForm(System.IO.Path.GetDirectoryName(activeDoc.FullFileName))
    If form.ShowDialog() <> DialogResult.OK Then
        Return
    Dim outputFolder As String = form.OutputPath
    Dim overwriteFiles As Boolean = form.OverwriteFiles
    Dim distributeByMaterial As Boolean = form.DistributeByMaterial
    Dim includeQuantity As Boolean = form.IncludeQuantity ' Save checkbox state
    Dim filterSheetMetal As Boolean = form.FilterSheetMetal ' Save checkbox state
    ' Iterate through all selected components of the assembly and subassemblies
    For Each oSelectedOcc As ComponentOccurrence In selectedObjects
        ' Check the BOM structure type
        Dim bomStructure As BOMStructureEnum = oSelectedOcc.Definition.BOMStructure
        If bomStructure = BOMStructureEnum.kPurchasedBOMStructure OrElse bomStructure = BOMStructureEnum.kPhantomBOMStructure OrElse bomStructure = BOMStructureEnum.kReferenceBOMStructure OrElse bomStructure = BOMStructureEnum.kInseparableBOMStructure Then
            Continue For
        ' Filter sheet metal
        If filterSheetMetal AndAlso IsSheetMetal(oSelectedOcc) Then
            Continue For
        ' Get the part number
        Dim partNumber As String = oSelectedOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
        ' Add the part number to the unique set
        uniqueParts.Add(partNumber)
    Next
    ' Count all occurrences of unique parts in the assembly and subassemblies
    CountOccurrences(asmCompDef.Occurrences, uniqueParts, partDict, materialDict, filterSheetMetal)
    ' Check the existence of the folder and create it if necessary
    If Not System.IO.Directory.Exists(outputFolder) Then
        System.IO.Directory.CreateDirectory(outputFolder)
    ' Check for the existence of the STEP export add-in
    Dim addInId As String = "{90AF7F40-0C01-11D5-8E83-0010B541CD80}"
    Dim oExport As TranslatorAddIn = Nothing
    Try
        oExport = invApp.ApplicationAddIns.ItemById(addInId)
        If oExport Is Nothing Then
            System.Windows.Forms.MessageBox.Show("STEP Translator add-in not found.")
            Return
        ' Activate the add-in if it is not activated
        If Not oExport.Activated Then
            oExport.Activate()
                System.Windows.Forms.MessageBox.Show("Failed to activate STEP Translator add-in.")
                Return
        System.Windows.Forms.MessageBox.Show("Error getting TranslatorAddIn: " & ex.Message)
        Return
    End Try
    ' Export each part to a .step file, taking into account the number of occurrences
    Dim exportedFiles As Integer = 0
    Dim overwrittenFiles As Integer = 0
    Dim skippedFiles As Integer = 0
    For Each kvp As KeyValuePair(Of String, Integer) In partDict
        ' Get the part number and quantity
        Dim partNumber As String = kvp.Key
        Dim qty As Integer = kvp.Value
        ' Get the part material from the dictionary
        Dim material As String = materialDict(partNumber)
        ' Create the output file name
        Dim materialFolder As String = outputFolder
        If distributeByMaterial Then
            materialFolder = System.IO.Path.Combine(outputFolder, material)
            If Not System.IO.Directory.Exists(materialFolder) Then
                System.IO.Directory.CreateDirectory(materialFolder)
        ' Modify the file name depending on the state of includeQuantity
        Dim outputFileName As String
        If includeQuantity Then
            outputFileName = System.IO.Path.Combine(materialFolder, partNumber & " - " & qty.ToString() & ".step")
        Else
            outputFileName = System.IO.Path.Combine(materialFolder, partNumber & ".step")
        ' Check if a file with the same partNumber exists and whether it needs to be overwritten
        Dim existingFiles As String() = System.IO.Directory.GetFiles(materialFolder, partNumber & "*.step")
        If existingFiles.Length > 0 AndAlso Not overwriteFiles Then
            skippedFiles += 1
            Continue For
        ' Delete all files with the same partNumber when overwriting
        If overwriteFiles Then
            DeleteFilesByPartNumber(outputFolder, partNumber)
                DeleteFilesByPartNumber(materialFolder, partNumber)
        ' Get the part document via ComponentDefinition
        Dim partDoc As Document = GetPartDocument(asmCompDef.Occurrences, partNumber)
        ' Check that partDoc is not Nothing
        If partDoc Is Nothing Then
            System.Windows.Forms.MessageBox.Show("Failed to find document for part: " & partNumber)
            Continue For
        ' Create export options
        Dim oContext As TranslationContext = invApp.TransientObjects.CreateTranslationContext
        oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        Dim oOptions As NameValueMap = invApp.TransientObjects.CreateNameValueMap
        If oExport.HasSaveCopyAsOptions(partDoc, oContext, oOptions) Then
            oOptions.Value("ApplicationProtocolType") = 214 ' AP214
        Dim oData As DataMedium = invApp.TransientObjects.CreateDataMedium
        oData.FileName = outputFileName
        ' Perform the export
        Try
            oExport.SaveCopyAs(partDoc, oContext, oOptions, oData)
            exportedFiles += 1
            If System.IO.File.Exists(outputFileName) Then
                overwrittenFiles += 1
            System.Windows.Forms.MessageBox.Show("Error exporting part " & partNumber & ": " & ex.Message)
        End Try
    Next
    ' Delete empty subdirectories
        DeleteEmptyDirectories(outputFolder)
    Dim message As String = "Export completed." & vbCrLf & "Files saved to: " & outputFolder & vbCrLf
    message &= "Number of unique files: " & exportedFiles.ToString() & vbCrLf
    If overwrittenFiles > 0 Then
        message &= "Number of overwritten files: " & overwrittenFiles.ToString() & vbCrLf
    If skippedFiles > 0 Then
        message &= "Number of skipped files: " & skippedFiles.ToString()
    Dim resultForm As New ExportResultForm(message, outputFolder)
    resultForm.ShowDialog()
End Sub
Private Sub CountOccurrences(occurrences As ComponentOccurrences, uniqueParts As HashSet(Of String), partDict As Dictionary(Of String, Integer), materialDict As Dictionary(Of String, String), filterSheetMetal As Boolean)
    For Each occ As ComponentOccurrence In occurrences
        If TypeOf occ.Definition.Document Is PartDocument Then
            Dim partNumber As String = occ.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
            If filterSheetMetal AndAlso IsSheetMetal(occ) Then
                Continue For
            If uniqueParts.Contains(partNumber) Then
                If partDict.ContainsKey(partNumber) Then
                    partDict(partNumber) += 1
                Else
                    partDict(partNumber) = 1
                ' Get the part material and add it to the dictionary
                Dim material As String = GetMaterialForPart(occ.Definition.Document)
                If Not materialDict.ContainsKey(partNumber) Then
                    materialDict(partNumber) = material
        ElseIf TypeOf occ.Definition.Document Is AssemblyDocument Then
            CountOccurrences(occ.SubOccurrences, uniqueParts, partDict, materialDict, filterSheetMetal)
    Next
End Sub
Private Function GetPartDocument(occurrences As ComponentOccurrences, partNumber As String) As Document
            If occ.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value = partNumber Then
                Return occ.Definition.Document
            Dim doc As Document = GetPartDocument(occ.SubOccurrences, partNumber)
            If doc IsNot Nothing Then
                Return doc
    Next
    Return Nothing
End Function
Private Function GetMaterialForPart(doc As Document) As String
    Try
        Return doc.ComponentDefinition.Material.Name
        Return ""
    End Try
End Function
Private Sub DeleteFilesByPartNumber(folder As String, partNumber As String)
    Dim dirInfo As New DirectoryInfo(folder)
    ' Delete files from the root folder
    Dim filesToDelete As FileInfo() = dirInfo.GetFiles(partNumber & "*.step")
    For Each file As FileInfo In filesToDelete
        File.Delete()
    Next
    ' Delete files from subdirectories
    Dim subDirs As DirectoryInfo() = dirInfo.GetDirectories()
    For Each dir As DirectoryInfo In subDirs
        filesToDelete = Dir.GetFiles(partNumber & "*.step")
            File.Delete()
        Next
    Next
End Sub
Private Sub DeleteEmptyDirectories(ByVal directory As String)
    Dim rootDirectoryInfo As New DirectoryInfo(directory)
    Dim directoriesToCheck As DirectoryInfo() = rootDirectoryInfo.GetDirectories("*", SearchOption.AllDirectories)
    For Each subDirectory As DirectoryInfo In directoriesToCheck
        If subDirectory.GetFiles().Length = 0 AndAlso subDirectory.GetDirectories().Length = 0 Then
            subDirectory.Delete()
    Next
End Sub
Private Function IsSheetMetal(occ As ComponentOccurrence) As Boolean
    Try
        Return occ.Definition.Document.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
        Return False
    End Try
End Function
Public Class ExportResultForm
    Inherits Form
    Public Sub New(message As String, outputFolder As String)
        Me.Text = "Export Results"
        Me.Width = 400
        Me.Height = 200
        Dim label As New Label()
        label.Text = message
        label.AutoSize = True
        label.Top = 20
        label.Left = 20
        Dim buttonOpenFolder As New Button()
        buttonOpenFolder.Text = "Open folder"
        buttonOpenFolder.AutoSize = True
        buttonOpenFolder.Top = 100
        buttonOpenFolder.Left = 20
        AddHandler buttonOpenFolder.Click, Sub(sender, e)
                                               Process.Start("explorer.exe", outputFolder)
                                           End Sub
        Dim buttonOK As New Button()
        buttonOK.Text = "OK"
        buttonOK.Top = 100
        buttonOK.Left = 300
        AddHandler buttonOK.Click, Sub(sender, e)
                                       Me.Close()
                                   End Sub
        Me.Controls.Add(label)
        Me.Controls.Add(buttonOpenFolder)
    End Sub
End Class
INV 2025.3
Replies (0)
