Export to pdf with the name of the sheet
DeptaM
DeptaM
Good day,
I have a rule for exporting from a drawing to PDF one sheet at a time. The file is always saved with the file name IDW. I need it to be saved with the sheet name.
Thank you for your help.
Sub Main PublishPDF()
    ' Get the PDF translator Add-In.
    Dim PDFAddIn As TranslatorAddIn
    PDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
    ' a reference to the active document (the document to be published).
    Dim oDocument As Document
     oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
     oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
     oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
     oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oOptions.Value("Sheet_Range") = kPrintCurrentSheet
    ' Check whether the translator has 'SaveCopyAs' options
    If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        ' Options for drawings...
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintCurrentSheet
        oOptions.Value("All_Color_AS_Black") = 0
' oOptions.Value("Sheet_Range") = kPrintAllSheet
        'oOptions.Value("Remove_Line_Weights") = 0
        'oOptions.Value("Vector_Resolution") = 400
        'oOptions.Value("Custom_Begin_Sheet") = 2
        'oOptions.Value("Custom_End_Sheet") = 4
    ' the destination file name
'oDataMedium.FileName = ThisDoc.PathAndFileName(False)&".pdf"
Dim sPath = ThisDoc.Path
Dim sFolder = "Výkresy PDF"
Dim sFile = ThisDoc.FileName(False)
Dim oPDFFolder = System.IO.Path.Combine(sPath, sFolder)
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oPDFFolder) Then
    System.IO.Directory.CreateDirectory(oPDFFolder)
oDataMedium.FileName = System.IO.Path.Combine(sPath, sFolder, sFile & ".pdf")
' Dim outputFile As String
' outputFile = ThisDoc.PathAndFileName(False)&"_"&iProperties.Value("Project", "Revision Number")&".pdf"
    'Publish document.
    Call PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Andrii_Humeniuk
Hi @DeptaM . I made some changes to your code. Now it works properly. Try it please.
	Dim oInvApp As Inventor.Application
	oInvApp = ThisApplication
	PDFAddIn = oInvApp.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
	oDocument = oInvApp.ActiveDocument
	If Not TypeOf oDocument Is DrawingDocument Then Exit Sub
	Dim oDDoc As DrawingDocument
	oDDoc = oDocument
	oContext = oInvApp.TransientObjects.CreateTranslationContext
	oOptions = oInvApp.TransientObjects.CreateNameValueMap
	oDataMedium = oInvApp.TransientObjects.CreateDataMedium
	Dim sPath = IO.Path.GetDirectoryName(oDocument.FullDocumentName)
	Dim sFile = oDDoc.ActiveSheet.Name
	sFile = sFile.Replace(":", "(") & ")"
	'Publish document.
End Sub
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
DeptaM
Good day,
thank you very much, this helped me.
Have a nice day
