Export to DXF
Export to DXF
marc.cortada396VM
Export to DXF
marc.cortada396VM
Hi to everyone.
Actually i'm using this code to save the sheet 1 in pdf.
oPath = ThisDoc.Path
oFileName = Parameter("04.01 Tapa aspiracion TMB.ipt.CODIGO_TMB")& ".04.01 " & Parameter("04.01 Tapa aspiracion TMB.ipt.DENOMINACION_TMB") 'without extension
oRevNum = iProperties.Value("project", "revision number")
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById _
("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}")
oDocument = ThisApplication.ActiveDocument
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
If oPDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
oOptions.Value("All_Color_AS_Black") = 0
oOptions.Value("Remove_Line_Weights") = 1
oOptions.Value("Vector_Resolution") = 400
oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange
oOptions.Value("Custom_Begin_Sheet") = 1
oOptions.Value("Custom_End_Sheet") = 1
'get PDF target folder path
oFolder = ThisDoc.Path
'Check for the PDF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
    System.IO.Directory.CreateDirectory(oFolder)
 'Set the PDF target file name
oDataMedium.FileName = oFolder & "\" & oFileName & ".pdf"
'Publish document
oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
'------end of iLogic-------
I would like to save the sheet 2 to DXF. With the same name and everything the same.
I tried many times but I don't know how to do it.
Any ideas?
Thanks in advance!
A.Acheson
You will need to prepare a seperate rule to process the dxf at least untill you figure out the process. The API sample has a dxf export macro written in VBA. The next thing is you want to target sheet 2 but the export rule expects there only to be one sheet. So it really won't work as you expect. The alternative is to copy your sheet to a temporary drawing and export that drawing. Discussed in this post here. Have a look at those and see what makes sense to your workflow.
Yet another method is to export the flatpattern via the model reference of the drawing. The down side here is you need to hardcode in the export settings that would normally be taken care of in the ini file of the drawing export to dxf.
Regards
Alan
