Export to DWG and move older version - Several sheets drawing
guiherme.leite.relco
I have this code to export to PDF and Autocad DWG and move older version to an "OldVersions" folder.
The problem is when the drawing has more than one sheet. The exported dwg file come with "_Sheet_X.dwg" and don't move the older version. I have tried lots of things and tips that I found her, but nothing worked.
Can you help me solve it?
Sub Main
	For Each doc As Document In ThisApplication.Documents.VisibleDocuments
		If doc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
			Call Save_As_DWG_CAD(doc)
	Next
			Call Save_As_PDF(doc)
	Next
	MessageBox.Show("All files created", "Ready!", MessageBoxButtons.OK)
End Sub
Sub Save_As_DWG_CAD(oDoc As Document)
	oPath = IO.Path.GetDirectoryName(oDoc.FullFileName)
	oFileName = IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'without extension
	oRevNum = oDoc.PropertySets.Item(1).Item("Revision Number").Value
	Dim DWGAddIn As TranslatorAddIn
	DWGAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
	'oDocument = ThisApplication.ActiveDocument
	Dim oContext As TranslationContext
	oContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = kFileBrowseIOMechanism
    'Create a NameValueMap object
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    'Create a DataMedium object
    Dim oDataMediumDWG As DataMedium
	oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium
	'oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
	'Sets the directory that the file should be saved in
	oFolder = oPath & "\2D_CAD"
	'checks to see if that directory exists, if not, it is created
	If Not System.IO.Directory.Exists(oFolder) Then
		System.IO.Directory.CreateDirectory(oFolder)
	oFile = oFileName & "_" & oRevNum & ".dwg"
	'Saves the file in the desired location
	oDataMediumDWG.FileName = oFolder + "\" + oFile
		Dim strIniFile As String
    strIniFile = "Z:\Biblioteca 3D\Ilogic\saveDWG_CAD.ini"
	oOptions.Value("Export_Acad_IniFile") = strIniFile
	'Check to see if the file already exists, if it does, ask if you want to overwrite it or not.
	If System.IO.File.Exists(oDataMediumDWG.FileName) = True Then
		oAnswer = MsgBox( oFile & " already exists." & vbCrLf &
		"Do you want to overwrite it?", vbYesNo + vbQuestion + vbDefaultButton2, "DWG ALREADY EXISTS")
		If oAnswer = vbNo Then Exit Sub
	'Publish document
	DWGAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMediumDWG)
	'Colocar revisao anterior em OldVersions
	If oRevNum >= "A" Then
	Dim EarlyRev As String = Chr(Asc(oRevNum) -1)
	Dim FileCurrentName = oFileName & "_" & EarlyRev & ".dwg"
	Dim FileCurrent As String = oFolder & "\" & FileCurrentName
	Dim oObs As String = oFolder & "\OldVersions\"
	Dim FileObs As String = oObs & FileCurrentName
		If Not System.IO.Directory.Exists(oObs) Then
    		System.IO.Directory.CreateDirectory(oObs)
  		If System.IO.File.Exists(FileCurrent) = True Then
		    System.IO.File.Move(FileCurrent, FileObs)
End Sub
JelteDeJong
maybe this works for you:
Public Sub Save_As_DWG_CAD(oDoc As Document)
	Dim oPath = IO.Path.GetDirectoryName(oDoc.FullFileName)
	Dim oFileName = IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName) 'without extension
	Dim oRevNum = oDoc.PropertySets.Item(1).Item("Revision Number").Value
	Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
	Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
	oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
	Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
	Dim oDataMediumDWG As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
	Dim oFolder = IO.Path.Combine(oPath, "2D_CAD")
	Dim dirInfo As New IO.DirectoryInfo(oFolder)
	If Not dirInfo.Exists Then dirInfo.Create()
	' Move old versions
		Dim oldVersionsFolderName = IO.Path.Combine(dirInfo.FullName, "OldVersions")
		Dim oldVersionsFolderInfo As New IO.DirectoryInfo(oldVersionsFolderName)
		If Not oldVersionsFolderInfo.Exists Then oldVersionsFolderInfo.Create()
		For Each fileInfo As IO.FileInfo In dirInfo.GetFiles(oFileName & "*.dwg")
			Dim newFileName = IO.Path.Combine(oldVersionsFolderInfo.FullName, fileInfo.Name)
			fileInfo.MoveTo(newFileName)
		Next
	'Create new file name
	Dim oFile = String.Format("{0}_{1}.dwg", oFileName, oRevNum)
	oDataMediumDWG.FileName = IO.Path.Combine(oFolder, oFile)
	oOptions.Value("Export_Acad_IniFile") = "Z:\Biblioteca 3D\Ilogic\saveDWG_CAD.ini"
		Dim oAnswer = MsgBox(oFile & " already exists." & vbCrLf &
	'Publish document
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
At first, it worked. But when I try overwrite, I get an error, it says is "not allowed to create an existent file".
In the rule there's a part to check if I want to overwrite, but doesn't works, apparently.
