export tapping and threading annotations to excel
Thomas_DIETSCHYFXTLC
I have a problem, I wrote a rule that allows me to export the dimensions and tolerances to an Excel file, all works except the export of the thread and tapping annotations. Do you have any ideas?
WCrihfield
Hi @Thomas_DIETSCHYFXTLC.  I think we would need to know more about how you are currently doing what you are doing before we could help you fix or add to what you are currently doing.  One thought that comes to mind is that if you used the 'Hole and Thread' tool in the 'Feature Notes' panel of the Annotate tab in a drawing to place those 'tapping & threading annotations', those are not normal LeaderNote type DrawingNote, those are HoleThreadNote objects, so you may not be getting the correct objects to export data from.
Wesley Crihfield
(Not an Autodesk Employee)
I would like to export the tapping and persage notes to excel, the problem is that I can't find a solution!
