Export Specific Model State To .step & .dxf File
matthew.johnson200
Message 1 of 8
matthew.johnson200
We currently have a rule which goes through the parts in an assembly and exports .step & .dxf files for any parts that need to be sent to a supplier for manufacture. The code we have works great for what we need it to do.
We have recently installed Inventor 2022.1 and we are starting to use models states to show pre-production parts as well as the final part e.g. a hollow section that we buy in blank but then drill holes out in the workshop. What I would like is for the rule to be tweaked so that before exporting each part, it will check if it has a model state named 'Pre-Production'. If it does then it should export the .step & .dxf file using that model state. If its not there, then just export using the master model state (as not all parts require a pre-production model state).
I have attached our current code.
Thanks in advance.
Sub Main()
	Dim ans As String
	ans = MessageBox.Show("Before running this rule, please check the following:" + vbCrLf + "" + vbCrLf + "For parts where the face side is critical e.g. polished stainless steel, please make sure to create a flat pattern manually or define an A-Side" + vbCrLf + "" + vbCrLf + "Inventor will ask you to check out any files that are not checked out that need to be flat patterned.", "Caution", MessageBoxButtons.OKCancel, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
	If ans = vbCancel Then
		Exit Sub
	'CREATE FOLDER / CHECK IF EXISTS
    Dim fdObj As Object
    fdObj = CreateObject("Scripting.FileSystemObject")
    If fdObj.FolderExists("C:\KIT OF PARTS") Then
        'DO NOTHING
    Else
    	fdObj.CreateFolder("C:\KIT OF PARTS")
    Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
    TraverseAssembly(oAsmDoc.ComponentDefinition.Occurrences, 1)
	MessageBox.Show("KIT OF PARTS SAVED IN C:\KIT OF PARTS", "Title")
	fOPath = "C:\KIT OF PARTS\"
	Call Shell("explorer.exe " & fOPath, vbNormalFocus)
End Sub
Sub TraverseAssembly(Occurrences As ComponentOccurrences, Level As Integer)
    Dim oOcc As ComponentOccurrence
	'STEP CREATOR
    Dim oContext As TranslationContext
    oContext = ThisApplication.TransientObjects.CreateTranslationContext
    Dim oOptions As NameValueMap
    oOptions = ThisApplication.TransientObjects.CreateNameValueMap
	Dim oSTEPTranslator As TranslatorAddIn
	oSTEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
	If oSTEPTranslator Is Nothing Then
		MessageBox.Show("Could not access STEP translator.", "ERROR")
	    Exit Sub
    For Each oOcc In Occurrences
	    If oOcc.Suppressed Then
			'DONT CREATE STEP FILE FOR SUPPRESSED FILES
        Else 'not suppressed
		        If oOcc.DefinitionDocumentType = kAssemblyDocumentObject Then
	                'DONT CREATE STEP FILE FOR ASSEMBLY FILES
                	Call TraverseAssembly(oOcc.SubOccurrences, Level + 1)
            	Else 'NOT ASSY
	                If oOcc.BOMStructure = 51972 Or oOcc.BOMStructure = 51971 Then
	                    'PART SET TO REF.OR PHANTOM DO NOT CREATE STEP
	                Else
	                    'CHECK IF PARAMETER EXISTS
						Try
		                    If oOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("Purchased").Value = "-" And _
							   oOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("Stores").Value = "-" And _
							   oOcc.Definition.Document.PropertySets.Item("Inventor User Defined Properties").Item("Laser Stock").Value = "-" Then
								'CHECK IF ALREADY EXIST
								DPS = ThisDoc.Document.PropertySets.Item("Design Tracking Properties")
								ISI = ThisDoc.Document.PropertySets.Item("Inventor Summary Information")
								Dim PN As String
								Dim REVI As String
								PN = oOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value
								REVI = oOcc.Definition.Document.PropertySets.Item("Inventor Summary Information").Item("Revision Number").Value
								'CHECK IF STEP ALREADY EXISTS
								If Not Dir("C:\KIT OF PARTS\" & PN & " - " & REVI & ".stp", vbDirectory) = vbNullString Then
								    'FILE ALREADY EXISTS - SKIP
								Else
									'OPEN FILE
			                    	oNewDoc = ThisApplication.Documents.Open(oOcc.Definition.Document.FullFileName, True)
										If TypeOf ThisApplication.ActiveDocument.ComponentDefinition Is SheetMetalComponentDefinition Then
											'FLAT PATTERN FUNCTIONS
											Dim oDoc As PartDocument
											oDoc = ThisApplication.ActiveDocument
											Dim oCompDef As SheetMetalComponentDefinition
											oCompDef = oDoc.ComponentDefinition
											If oCompDef.HasFlatPattern = False Then
												oCompDef.Unfold
											Else
												oCompDef.FlatPattern.Edit
											'FLAT PATTERN DXF Settings
											Dim sOut As String
											Dim sPATH As String
											sOut = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES"
											Dim sFname As String
											sFname = "C:\KIT OF PARTS\" & PN & " - " & REVI & ".DXF"
											'Export the DXF and fold the model back up
											oCompDef.DataIO.WriteDataToFile( sOut, sFname)
											Dim oSMDef As SheetMetalComponentDefinition
											oSMDef = oDoc.ComponentDefinition
											oSMDef.FlatPattern.ExitEdit
											'END OF FLAT PATTERN FUNCTIONS
								    If oSTEPTranslator.HasSaveCopyAsOptions(ThisApplication.ActiveDocument, oContext, oOptions) Then
								        oOptions.Value("ApplicationProtocolType") = 3
								        oContext.Type = kFileBrowseIOMechanism
								        Dim oData As DataMedium
								        oData = ThisApplication.TransientObjects.CreateDataMedium
								        oData.FileName = "C:\KIT OF PARTS\" & PN & " - " & REVI & ".stp"
								        'Publish document.
								        Call oSTEPTranslator.SaveCopyAs(oNewDoc, oContext, oOptions, oData)
									'Check for flat pattern >> create one if needed
			                    	oNewDoc.Close
						Catch
							'MessageBox.Show("PARAMETER MISSING", oOcc.Definition.Document.PropertySets.Item("Design Tracking Properties").Item("Part Number").Value)
						End Try
    Next
End Sub
Replies (7)
Message 2 of 8
WCrihfield
Hi @matthew.johnson200.  The new ModelStates in Inventor 2022 are still fairly new to most of us, so we're still exploring the possibilities and limits of what we are capable or not capable of doing with them, both manually, and especially by code.  The ModelState object has a couple of Properties that represent Document object.  One is called just called "Document" (ModelState.Document), and the other is called "FactoryDocument" (ModelState.FactoryDocument).  The one just called Document is supposed to return the "model state member Document that associates with this model state", while the one called FactoryDocument is supposed to return the "model state factory Document", and also notes "If the model state factory document is not open, query this property will cause it open."  The term 'member' coincides with the terminology used with iParts, iAssemblies, & iFeatures, which would represent a simple 'slave' type resulting document with a single set of specifications, while the term 'factory' would represent the one main document which contains all specifications for all variations of the parts, assemblies, or features, and is used to generate the 'member' documents.  Knowing this, I would assume you could get the ModelState.Document (again, a Document object) from the ModelState (if one other than "Master" is found) and use that as the input to your Export process.  I believe that would ensure the model would be set-up according to the settings in that specific model state.
PS.  If using the ModelState.Document doesn't work in your tests, try using the Document returned from the ModelState.FactoryDocument, just to be thorough.  If your testing succeeds with one, but not the other, be sure and let us know which one is working for you, and/or which one fails.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
JelteDeJong
I did have a look at your code and changed it so I could understand better how it works. Here is it all but for your question in the opening post you only need the function: "GetModelStateDocument()"
In that function, the correct model state is activated end returns the correct document.
Public Class ThisRule
    Private _STEPTranslator As TranslatorAddIn
    Private Const _sheetMetalPartGUID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
    Private Const _mainExportFolder = "C:\KIT OF PARTS"
    Sub Main()
        Dim ans As String = MessageBox.Show("Before running this rule, please check the following:" +
                "For parts where the face side is critical e.g. polished stainless steel, " +
				"please make sure to create a flat pattern manually or define an A-Side" +
            Exit Sub
        If (IO.Directory.Exists(_mainExportFolder) = False) Then
            IO.Directory.CreateDirectory(_mainExportFolder)
        SetSTEPTranslator()
        Dim doc As AssemblyDocument = ThisDoc.Document
        Dim refDocs = doc.AllReferencedDocuments.Cast(Of Document).Where(AddressOf NeedExport)
        For Each refDoc As Document In refDocs
            refDoc = ThisApplication.Documents.Open(refDoc.FullFileName, True)
            refDoc = GetModelStateDocument(refDoc)
            ExportDxf(refDoc)
            ExportStep(refDoc)
            ' refDoc.Close()
        Next
         MessageBox.Show("KIT OF PARTS SAVED IN: " & _mainExportFolder, "Title")
         Call Shell("explorer.exe " & _mainExportFolder, vbNormalFocus)
    End Sub
    Public Function GetModelStateDocument(doc As PartDocument)
        Dim def As PartComponentDefinition = doc.ComponentDefinition
        If (def.IsModelStateMember Or def.IsModelStateFactory) Then
            doc = def.FactoryDocument
            def = doc.ComponentDefinition
        Else
            Return doc
        Dim masterDoc As Document = Nothing
        Dim PreProductionDoc As Document = Nothing
        For Each modelState As ModelState In def.ModelStates
            If (ModelState.Name = "Master") Then
                If (PreProductionDoc Is Nothing) Then
                    ModelState.Activate()
                masterDoc = ModelState.FactoryDocument
            If (ModelState.Name = "Pre-Production") Then
                PreProductionDoc = ModelState.FactoryDocument
        Next
            Return masterDoc
        Else
            Return PreProductionDoc
    End Function
    Private Sub ExportDxf(oDoc As Document)
        If (oDoc.SubType = _sheetMetalPartGUID) Then
            Dim oCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
                oCompDef.Unfold()
            Else
                oCompDef.FlatPattern.Edit()
            Dim DPS As PropertySet = oDoc.PropertySets.Item("Design Tracking Properties")
            Dim ISI As PropertySet = oDoc.PropertySets.Item("Inventor Summary Information")
            Dim fileName As String = String.Format("{0}\{1} - {2}.dxf",
                _mainExportFolder,
                DPS.Item("Part Number").Value,
                ISI.Item("Revision Number").Value)
            Dim sOut As String = "FLAT PATTERN DXF?AcadVersion=2004&RebaseGeometry=True&OuterProfileLayer=0&OuterProfileLayerColor=0;0;0&InteriorProfilesLayer=0&InteriorProfilesLayerColor=0;0;0;IV_OUTER_PROFILE;IV_INTERIOR_PROFILES;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_ALTREP_FRONT;IV_ALTREP_BACK;IV_ROLL_TANGENT;IV_ROLL&InvisibleLayers=IV_BEND;IV_BEND_DOWN;IV_TANGENT;IV_TOOL_CENTER;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_UNCONSUMED_SKETCHES"
            oCompDef.DataIO.WriteDataToFile(sOut, fileName)
            oCompDef.FlatPattern.ExitEdit()
    End Sub
    Private Sub ExportStep(oDoc As Document)
        Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
        Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
        Dim fileName As String = String.Format("{0}\{1} - {2}.stp",
                _mainExportFolder,
        If _STEPTranslator.HasSaveCopyAsOptions(oDoc, oContext, oOptions) Then
            oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
            oData.FileName = fileName
            'Publish document.
            Call _STEPTranslator.SaveCopyAs(oDoc, oContext, oOptions, oData)
    End Sub
    Public Function findAllWhere(doc As AssemblyDocument,
                predicate As Func(Of ComponentOccurrence, Boolean)) As IEnumerable(Of ComponentOccurrence)
        Dim list As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Occurrences.Cast(Of ComponentOccurrence).
        Where(predicate)
        Dim assemblyList As IEnumerable(Of ComponentOccurrence) = doc.ComponentDefinition.
        Where(Function(o) o.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject)
        For Each assOcc As ComponentOccurrence In assemblyList
            If TypeOf assOcc.Definition Is VirtualComponentDefinition Then Continue For
            Dim assDoc As AssemblyDocument = assOcc.ReferencedDocumentDescriptor.ReferencedDocument
            Dim listToAdd As IEnumerable(Of ComponentOccurrence) = findAllWhere(assDoc, predicate)
            list = list.Concat(listToAdd)
        Next
        Return list
    End Function
    Private Function NeedExport(doc As Document) As Boolean
        If (doc.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject) Then Return False
        If (doc.ComponentDefinition.BOMStructure = BOMStructureEnum.kReferenceBOMStructure) Then Return False
        If (doc.ComponentDefinition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure) Then Return False
        Dim UDP As PropertySet = doc.PropertySets.Item("Inventor User Defined Properties")
        Dim DPS As PropertySet = doc.PropertySets.Item("Design Tracking Properties")
        Dim ISI As PropertySet = doc.PropertySets.Item("Inventor Summary Information")
        If (UDP.Item("Purchased").Value = "-" And UDP.Item("Stores").Value = "-" And
                UDP.Item("Laser Stock").Value = "-") = False Then Return False
                _mainExportFolder,
        If (IO.File.Exists(fileName)) Then Return False
        Return True
    End Function
    Private Function SetSTEPTranslator()
        _STEPTranslator = ThisApplication.ApplicationAddIns.ItemById("{90AF7F40-0C01-11D5-8E83-0010B541CD80}")
        If _STEPTranslator Is Nothing Then
            Throw New Exception("Could not access STEP translator.")
    End Function
End Class
Jelte de Jong
Blog: hjalte.nl - github.com
Message 4 of 8
matthew.johnson200
This works great. Thanks for your help!
Message 5 of 8
dalton98
@JelteDeJong
I have a code very similar that I use. We only burn certain parts so we just eye test them in our drawing sets. I wrote a rule that exports the first view in the active sheet as a ".dxf", but it doesn't work with model states.
'get view document
Dim
oDoc As PartDocument oDoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
Dim oCompDef As SheetMetalComponentDefinition oCompDef = oDoc.ComponentDefinition
'''''code
I tried doing this
oDoc = oCompDef.FactoryDocument
 Any feedback would be greatly appreciated.
Message 6 of 8
dalton98
Nvm. I did this and it worked fine
Dim oDoc As Document
oDoc = oDoc.ComponentDefinition.Document
Message 7 of 8
basslagter
Hi @dalton98 ,
I am also working on a code to export all model states from a drawing document. Did you manage to do that, and would you mind sharing the whole code?
If so, thanks in advance.
If not, please let me know as well.
Message 8 of 8
dalton98
@basslagter The problem I was having was trying to unfold the model states. I ended up creating a separate rule for it. You should just make a post on the forums and tell what you are exactly trying to do and someone will help.
Heres a snippet of mine
SETFilePath = ThisApplication.DesignProjectManager.ActiveDesignProject.WorkspacePath & "/"
Dim oDrawingDoc As DrawingDocument
oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
For Each oSheet In oDrawingDoc.Sheets
Dim oView As DrawingView
oView = oSheet.DrawingViews.Item(1)
If Not oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then Continue For
If Not oDoc.DocumentSubType.DocumentSubTypeID = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then Continue For
'DXF Settings
Dim sOut As String
Dim sPATH As String
sOut = "FLAT PATTERN DXF?AcadVersion=2000&OuterProfileLayer=IV_INTERIOR_PROFILES&TangentLayer=DELETE&ArcCentersLayer=DELETE&BendDownLayer=IV_BEND&UnconsumedSketchesLayer=DELETE"
sFname = SETFilePath & "\" & oDoc.PropertySets.Item(3).Item("Part Number").Value & " " & oDoc.PropertySets.Item(3).Item("Description").Value & ".dxf"
'ThisDoc.Launch("C:\Temp\Copy and Paste in AutoCad Command Box.txt")'open the file
Process.Start(sFname)
Next
