Export pdf on same computer in different o.s.
GosponZ
GosponZ
Hi to All,
i'm wandering if is possible to export pdf on computer with 2 O.S. I'm working in W7 but need export pdf in foldeer which is in win xp.
Thanks for any response
Owner2229
Hi, I believe it shouldn't be a problem, as all the folders from Win XP should be visible in Win 7 and vice versa.
Can you give us an example of as you see the folders in W7 / XP?
From Win 7:
   -folder where is the drawing stored
From Win XP
   -folder in which you want to save the PDF
Are the systems on different discs or on the same?
If different then as which drive lelter can you see in WIn 7 the drive that the Win XP is on?
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
GosponZ
folder in xp is not visible thru win7. I have to get first into XP mode to see desired folder. From xp you can't see nothing but desktop of xp mode. I hope there will be line or two of code to get into xp mode.
 I did try navigate path to c:\ xp_mode\folder but it is not working.
Please advanced programmers if you have any idea.
Thanks all
GosponZ
The network drive is maped from win 7 to xp mode and i can see my folder. So problem solved.
