Export Multi Body Part As Separate STL
ilyas_adnm
ilyas_adnm
Hi Everyone,
I have multi-body part files and I'd like to export each solid body into separate STL files via the API.
The workflow I have currently is to make components and create individual IPTs for each body, followed by running the following script to export them to STL.
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
For Each oOccurrence As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences
	Dim oCompDoc As PartDocument = oOccurrence.Definition.Document
	Dim stlName As String= System.IO.Path.GetFileNameWithoutExtension(oCompDoc.FullFileName)+".stl"
	Dim savePath As String = System.IO.Path.GetDirectoryName(oCompDoc.FullFileName)
	Logger.Trace(savePath & "\" & stlName)
	oCompDoc.SaveAs(savePath & "\" & stlName,True)
Next
MessageBox.Show("Done","ExportAllPartsAsSTL")
I'm wondering if there is a way to export the solid bodies directly via the API without having to go through the Make Component step?
Or if there is a way to access the 3D Print Environment via the API? Because in this environment, user can suppress individual bodies and export the remaining bodies as STL.
Regards
Ilyas
A.Acheson
Hi @ilyas_adnm
You can derive the solids to a part which is the same function as make components tool. See post here.
Found by searching ilogic make components.
Regards
Alan
ilyas_adnm
Hi @A.Acheson,
Thanks for the hint.
'ThisApplication.ScreenUpdating = False
Dim oActiveDoc As PartDocument = ThisApplication.ActiveDocument
For Each oSurfaceBody As SurfaceBody In oActiveDoc.ComponentDefinition.SurfaceBodies
	Dim oPartDoc As PartDocument = ThisApplication.Documents.Add(kPartDocumentObject)
	Dim oDerivedPartComponents As DerivedPartComponents = oPartDoc.ComponentDefinition.ReferenceComponents.DerivedPartComponents
	Dim oDerivedPartDef As DerivedPartUniformScaleDef = oDerivedPartComponents.CreateUniformScaleDef(oActiveDoc.FullDocumentName)
	For Each oDerivedPartEntity As DerivedPartEntity In oDerivedPartDef.Solids
      If Not oDerivedPartEntity.ReferencedEntity Is oSurfaceBody Then
        oDerivedPartEntity.IncludeEntity = False
    Next
	oDerivedPartComponents.Add(oDerivedPartDef)
	Dim iptName As String = System.IO.Path.GetFileNameWithoutExtension(oSurfaceBody.Name) + ".ipt"
	Dim stlName As String = System.IO.Path.GetFileNameWithoutExtension(oSurfaceBody.Name) + ".stl"
	Dim savePath As String = System.IO.Path.GetDirectoryName(oActiveDoc.FullFileName)
	oPartDoc.SaveAs(savePath & "\" & iptName, True) 'need to save ipt first before it will be able to save stl
	oPartDoc.SaveAs(savePath & "\" & stlName, True)
	oPartDoc.Close(True)
	System.IO.File.Delete(savePath & "\" & iptName)
Next
MessageBox.Show("Done", "ExportBodiesAsSTL")
'ThisApplication.ScreenUpdating = True
Regards
Ilyas
