Export model state in assy to step
Jos_Heruvent
Jos_Heruvent
Hi.
I have this code that exports all parts in de assy and sub assy's.
Now i went over to Inventor 2022 and use Model States.
I found a bit of code to use Model States.
But i don't have the knowledge to fit that bit of code in to the main code to make it work.
My main code that exports all the parts into a certain folder:
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = ThisDoc.FileName(False) 'without extension
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
    MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
    Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a STEP file for all components.")
'& vbLf & " " _
'& vbLf & "Are you sure you want to create STEP Drawings for all of the assembly components?" _
'& vbLf & "This could take a while.", "iLogic - Batch Output STEPs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
    Return
Else
'- - - - - - - - - - - - -STEP setup - - - - - - - - - - - -
oPath = "Z:\Uni_Link\Import\Stepfiles"
'get STEP target folder path
oFolder = oPath & "\" & iProperties.Value("Project","Project") & "-"  & iProperties.Value("Summary","Category") & " STEP Files"
'oFolder = oPath & "\" & oAsmName & " STEP Files"
'Check for the step folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Assembly - - - - - - - - - - - -
ThisDoc.Document.SaveAs(oFolder & "\" & oAsmName &(".stp") , True)
'- - - - - - - - - - - - -Components - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the referenced models
For Each oRefDoc In oRefDocs
    Dim oCurFile As Document
    oCurFile = ThisApplication.Documents.Open(oRefDoc.FullFileName, True)
    oCurFileName = oCurFile.FullFileName
    'defines backslash As the subdirectory separator
    Dim strCharSep As String = System.IO.Path.DirectorySeparatorChar
    'find the postion of the last backslash in the path
    FNamePos = InStrRev(oCurFileName, "\", -1)
    'get the file name with the file extension
    Name = Right(oCurFileName, Len(oCurFileName) - FNamePos)
    'get the file name (without extension)
    ShortName = Left(Name, Len(Name) - 4)
    Try
        oCurFile.SaveAs(oFolder & "\" & ShortName & (".stp") , True)
    Catch
        MessageBox.Show("Error processing " & oCurFileName, "ilogic")
    End Try
    oCurFile.Close
Next
MessageBox.Show("New Files Created in: " & vbLf & oFolder, "iLogic")
'open the folder where the new files are saved
Shell("explorer.exe " & oFolder,vbNormalFocus)
 This is the bit of code for Model States that is called CNC i think:
Public Function GetModelStateDocument(doc As PartDocument) Dim def As PartComponentDefinition = doc.ComponentDefinition If (def.IsModelStateMember Or def.IsModelStateFactory) Then doc = def.FactoryDocument def = doc.ComponentDefinition Else Return doc End If Dim masterDoc As Document = Nothing Dim PreProductionDoc As Document = Nothing For Each modelState As ModelState In def.ModelStates If (ModelState.Name = "Master") Then If (PreProductionDoc Is Nothing) Then ModelState.Activate() End If masterDoc = ModelState.FactoryDocument End If If (ModelState.Name = "CNC") Then ModelState.Activate() PreProductionDoc = ModelState.FactoryDocument End If Next If (PreProductionDoc Is Nothing) Then Return masterDoc Else Return PreProductionDoc End If
I hope someone can help me.
Jos_Heruvent
Is it possible to export the sub assy from the main assy as one step file.
So not all parts of every model state as a step file but the sub assy as a step file.
In another program I can load the assy step and all separate step parts are loaded there.
That means I don't have to load all parts separately.
I then get a folder 01 containing a folder 02 which contains a 02.step file. The same goes for 03.
