EXPORT ILOGIC PARTS FROM ASSEMBLY FOR DRAWING
enrico.silva1
enrico.silva1
I need help with an illogical code I'm a beginner with ilogic
Is there a way to create a code that automatically exports parts for drawings from an assembly? Taking quantities from the assembly itself?
ckeveryga
What do you mean by, "exports parts for drawings"?
  • Create drawings?
  • Open existing drawings?
  • Export drawings to PDF/DWG?
Also, what is the quantity used for?
enrico.silva1
I wanted to create the idw sheet for each ipt within an assembly
it's possible?
ckeveryga
It's possible, but you may want to start with creating a drawing for just one part. The code will be different depending on how you want your drawing to be formatted. After you have created your own rule for making drawings, it would be a lot easier to make all the drawings from an assembly.
