Export iLogic forms with input values into a database application (FileMaker?)
Hello World 🙂
How to export iLogic forms with input values (measurements of parts) into a database application, like FileMaker for example?
Aim is to create a datbase with measurements.
I have not worked with FileMaker before, it is just a database application I know.
Thank you for any ideas and suggestions! 🙂
bradeneuropeArthur
I know how to do that in Vb.net easily.
Are you using Vb.net forms within your design!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Thank you for your reply!
I don't use vb.net forms, I use iLogic forms.
I am open to any ideas.
