Export Flatpattern to DXF
I want to export our Flatpattern from a inv2008 ipt to DXF with only the contour lines. I only want the layers: OuterProfileLayer,InteriorProfilesLayer in my DXF file.
I tried this by InvisibleLayers but they still come in the DXF file
I use this code but I can't get it right.
Dim oDataIO As inventor.DataIO
Set oDataIO = oPartDoc.ComponentDefinition.DataIO
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=R12&OuterProfileLayer=0&InteriorProfilesLayer=0" & _
"&InvisibleLayers=FeatureProfilesLayer,ArcCentersLayer;BendLayer;BendUpLayer;BendDownLayer;BendUpLayer;BendDownLayer;ToolCenterLayer;ToolCenterUp Layer;ToolCenterDownLayer;" & _
"FeatureProfilesLayer;FeatureProfilesUpLayer;FeatureProfilesDownLayer" & _
"&SimplifySplines=True&MergeOuterContour=true"
strDXFname = "c:\temp\dxfout1.dxf" oDataIO.WriteDataToFile sOut, strDXFname
Geert
You must use the 'default' Inventor Layer Names and seperate them with a ";"
Example:
&InvisibleLayers="IV_TANGENT;IV_BEND"
HTH,
T. Ham
CAD Automation & Systems Administrator
CDS Engineering BV
HP xw4300 Workstation
Dual Pentium XEON 3.6 Ghz
4 GB SDRAM
NVIDIA QUADRO FX 3450/4000 SDI (Driver = 6.14.10.9185)
250 GB SEAGATE SATA Hard Disc
3Com Gigabit NIC
Windows XP Professional SP2
Autodesk Inventor Series 10 SP3a
Autodesk Inventor Suite 2008 SP1
Thanks Teun for your reply, I'll try it.
Geert
