Message 1 of 1
Export data from a SketchedSymbols
03:03 AM
Hello:
I leave you a code to export data from a SketchedSymbols.
SyntaxEditor Code Snippet:
Imports System.io Sub Main ' the name of the symbol is defined. SymbolName =InputBox("Simbol Name", "Export data symbol", "Symbol Name") readData(SymbolName) End Sub ''' Symbol data is read. Sub readData(SymbolName As String) Dim oIDW As DrawingDocument Dim oSheet As Sheet Dim oSheets As Sheets Dim oSymbol As SketchedSymbol Dim oSymbols As SketchedSymbols oIDW = ThisApplication.ActiveDocument oSheets = oIDW.Sheets For Each oSheet In oSheets For Each oSymbol In oSheet.SketchedSymbols If oSymbol.Name = SymbolName Then Dim strtexts As TextBoxes strtexts = oSymbol.Definition.Sketch.TextBoxes For Each strText In strtexts WriteFile(strText.text) Next End If Next Next End Sub ''' Data is written to the file defined in the parameter "FicheroDatos" Sub WriteFile(strContent As String) Dim fichero As System.io.streamwriter ' Add text to file defined in parameter "FicheroDatos". fichero = IO.File.AppendText(FicheroDatos) fichero.WriteLine(strContent) fichero.Flush() fichero.Close() End Sub
I hope will be useful.
