Export Coordinates from Inventor
mes063
mes063
Hello, I am trying to export the coordinates of the vertices of my line elements in the attached Inventor model. I have seen a few other Forum posts regarding exporting Inventor coordinates in Excel and have followed what was done there, but have had issues. https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/unable-to-export-3d-point-co-ordinat... and https://modthemachine.typepad.com/my_weblog/2011/06/writing-work-points-to-an-excel-file.html One of the codes kept giving me an error even after trying to fix it and the other produced a blank Excel sheet. Please let me know if you have any advice.
I am either trying to export my model as only lines, not solids, or trying to export the coordinates of the vertices of my model, as mentioned. Thank you so much for your help!
JelteDeJong
Does this work for you? It creates a csv file with the same file name as the part.
Sub Main()
	Dim doc As PartDocument = ThisDoc.Document
	Dim uom As UnitsOfMeasure = doc.UnitsOfMeasure
	Dim csvFileInfo As New IO.FileInfo(ThisDoc.PathAndFileName(False) & ".csv") 'Get file Names
	If csvFileInfo.Exists Then
		csvFileInfo.Delete()
	Using csvWriter As IO.StreamWriter = csvFileInfo.CreateText()
		csvWriter.WriteLine("sep=|")
		For Each body As SurfaceBody In doc.ComponentDefinition.SurfaceBodies
			For Each vertex As Vertex In body.Vertices
				Dim x As Double = Convert(uom, Vertex.Point.X)
				Dim y As Double = Convert(uom, Vertex.Point.Y)
				Dim z As Double = Convert(uom, Vertex.Point.Z)
				csvWriter.WriteLine(String.Format("{0}|{1}|{2}", x, y, z))
			Next
		Next
	End Using
End Sub
Private Function Convert(uom As UnitsOfMeasure, value As Double) As Double
	value = uom.ConvertUnits(value, UnitsTypeEnum.kDatabaseLengthUnits, UnitsTypeEnum.kDefaultDisplayLengthUnits)
	Return Math.Round(value, 10)
End Function
Jelte de Jong
Blog: hjalte.nl - github.com
