Export BOM to Excel change Excel Sheet Name
KWarrenCA
KWarrenCA
I created this iLogic to export a parts list in a drawing if it has a specific title. When it exports to the CSV file it also added the file name to the sheet name in excel. Is there a way to keep them all the same like "Sheet 1"? Our ERP software is going to import these csv files and it needs the sheet name to be the same for importing.
A.Acheson
You can add the options method to export  shown in this
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/ilogic-to-export-parts-list-to-xls-u...
Below is the relevant code and also extra options remove as necessary. Table Name is the excel sheet name.
' create a new NameValueMap object
oOptionsBOM = ThisApplication.TransientObjects.CreateNameValueMap
'specify an existing template file'to use For formatting colors, fonts, etc
oOptionsBOM.Value("Template") = "Y:\SUPPORT\Excel Templates\Purchasing BOM Template.xls"
'specify the columns to export
oOptionsBOM.Value("ExportedColumns") = "ITEM#;QTY;PART#;MATERIAL;DESCRIPTION;COMMENTS;COM CODE;TOTAL WT."
'specify the start cell
oOptionsBOM.Value("StartingCell") = "B11"
'specify the XLS tab name'here the file name is used
oOptionsBOM.Value("TableName") = "BILL OF MATERIALS"
'choose to include the parts list title row'in this example "Ye Old List of Parts" is written to the StartingCell
oOptionsBOM.Value("IncludeTitle") = False
'choose to autofit the column width in the xls file
oOptionsBOM.Value("AutoFitColumnWidth") = True
'get BOMrget folder path
oFolderBOM = Left(ExportPath, InStrRev(ExportPath, "\")) & "BOM"
'Check for the BOM folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolderBOM) Then
    System.IO.Directory.CreateDirectory(oFolderBOM)
' export the Partslist to Excel with options
oPartslist.Export(oFolderBOM & "\" & ThisDoc.FileName(False) & ".xls", PartsListFileFormatEnum.kMicrosoftExcel, oOptionsBOM)
Regards
Alan
KWarrenCA
So that works when I export to an xls file format but if I try and export to csv file format it doesn't work. I know in Inventor there are no options to select when exporting to csv is this a limitation of the export?
A.Acheson
From a quick scan of stack overflow a csv file when opened through excel will always display the csv filename as the excel sheet name. So this is a limitation of those operations and not necessarily the BOM export. If your program is opening the csv file directly you won’t likely have this problem. So the next question is do you need just a constant filename? If that is the case change the filename of your BOM export.
https://stackoverflow.com/questions/57628677/how-to-rename-sheet-name-different-from-file-name
Regards
Alan
