export body properties
eladm
eladm
Hello
Can I get help for ilogic rule to export body properties to excel (area , volume , mass)
From Multi body part or for single body
Regards
  • part
Michael.Navara
This information is accessible from MassProperties of each body
Dim part As PartDocument = ThisDoc.Document
Dim bodies As SurfaceBodies = part.ComponentDefinition.SurfaceBodies
For Each body As SurfaceBody In bodies
	Dim info As New System.Text.StringBuilder
	info.AppendLine("Name: " & body.Name)
	info.AppendLine(String.Format("Mass: {0:N2}", body.MassProperties.Mass))
	info.AppendLine(String.Format("Volume: {0:N2}", body.MassProperties.Volume))
	info.AppendLine(String.Format("Area: {0:N2}", body.MassProperties.Area))
	Logger.Debug(info.ToString())
Next
eladm
Hello
I run the rule , nothing happened ?  custom iProperties is empty , no user parameters were added and no Excel file was created
regards
Michael.Navara
This sample just show you how to access this information and print them to the iLogic log window. If you want to do something with this information you need to do it yourself.
