Export assembly as IFC
rbertoletti
rbertoletti
Hi guys,
I'd like to have a rule in my assembly which can export the model in IFC format. I know that it should be firstly simplified using the "BIM Content" because in other ways it's not possible.
JelteDeJong
I don't have the "Revit interoperability component" installed so I can't check it but it might work.
Dim fileName = "d:\temp\component.ifc"
Dim doc As AssemblyDocument = ThisDoc.Document
Try
    doc.ComponentDefinition.BIMComponent.ExportBuildingComponent(fileName)
Catch ex As Exception
    MsgBox("Did you install the Revit interoperability component?")
End Try
Jelte de Jong
Blog: hjalte.nl - github.com
rbertoletti
Thanks, It create correctly the IFC file but i don't know why it export an empty file.
The assembly to export is including sub-assemblies, maybe it could be the problem?
