Hi again,
I'm sorry but I'm not much of a coder and at this point don't have the knowledge to do much more in iLogic than relatively simple commands.
What I've been trying to do is automate the export of DXF files from the sheet named "FLAT PATTERN" from all the part drawings related to an assembly. I'd also like the file name of the DXF to be in the format "part_number"_REV"revision".DXF
The object types that I've wanting to export are "Visible View Edge" and "3D Sketch Geometry" objects, these are defaulting to Layer 0. I often use 3D Sketch Geometry in Dotted line type to indicate NC marking lines on the DXFs. Since layer 0 is set to continuous, I am overriding some of the line types of the 3D Sketch Geometry objects to ensure that I get a WYSIWYG output. I have a custom export configuration created called "ExportDXF2019.ini" which is currently giving me the expected line outputs when I manually export the "FLAT PATTERN" sheet.
On a related matter, I also want the export PDFs of the printable sheets of each drawing, again with the _REV"revision" suffix. I don't want this to be combined with the DXF export since I won't always want to do both together. This I think should be a little easier and I can likely find a script on the forum that will do it.
I've tried using Drawing Porter but there's not enough export options and the output is too messy (extra output files will need deleting, all output files will need renaming, etc). If it were possible to write sheet selection rules and file naming rules into the export configuration for Drawing Porter to then use that'd be great but I don't think such options exist. Likewise with Task Scheduler, the options that I'd like do not exist; there seems to be even less control over the process than with Drawing Porter.
Any help the iLogic pros can provide would be greatly appreciated.
