Export all part lists in a drawing to one excel file
eladm
Message 1 of 12
eladm
Hi
Can I get help of creating one excel file (drawing inventor file.xlsx) with all the part lists from all the sheets in the drawing ? I want a ilogic rule
I have this rule to create each part list to excel file (I want to combine the excel)
' Export Parts List to Excel'---------------------------
Sub main()
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Dim oPartList As PartsList
Dim Sheetcnt As Integer
Dim Partlistcnt As Integer
Dim filename As String
Sheetcnt = 1
Partlistcnt = 1
For Each oSheet In oDoc.Sheets
  For Each oPartList In oSheet.PartsLists          filename="C:\Temp\Sheet" & Sheetcnt & "_Partlist" & Partlistcnt & ".xlsx"
  MsgBox(filename)
    Partlistcnt = Partlistcnt + 1          Call oPartList.Export(filename, PartsListFileFormatEnum.kMicrosoftExcel)
Next
Sheetcnt=Sheetcnt+1
Next
End Sub
Thx in advance
Replies (11)
Message 2 of 12
A.Acheson
Here is a rule modified from here  See how it works for you.
Dim oDoc As Document = ThisDoc.Document
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheets As Sheets = oDrawDoc.Sheets
'get the path and name of the drawing file
Dim fileName = ThisDoc.PathAndFileName(False) & ".xlsx"
If (IO.File.Exists(fileName)) Then
    Dim result = MessageBox.Show("The file already exists: " & vbCr & vbCr & fileName & vbCr & vbCr & "Do you want to overwrite the file?", "File Exists", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
    If result = vbYes Then
        IO.File.Delete(fileName)
    Else
        Exit Sub
Else
Dim startRow = 2
Dim includeTitle = True
Dim PartsListNumber = 1
For Each sheet As Sheet In oSheets
    ThisApplication.StatusBarText = "Exporting Sheet " & Sheet.Name & " of " & oSheets.Count & "    Please Wait!"
    Try
        Dim oPartslist As PartsList = Sheet.PartsLists(1)
        ' create a new NameValueMap object
        Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap
        'specify an existing template file
        'to use For formatting colors, fonts, etc
        'oOptions.Value("Template") = ThisDoc.Path & "\BOM Template.xlsx"
        'specify the Columns To export
        oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
        'specify the start cell
        oOptions.Value("StartingCell") = "A" & startRow
        'specify the XLS tab name
        'here the file name is used
        oOptions.Value("TableName") = "PartsList-" & PartsListNumber 'without extension
        'choose to include the parts list title row
        'in this example "Ye Old List of Parts" is written to the StartingCell
        oOptions.Value("IncludeTitle") = False
        'choose to autofit the column width in the xls file
        oOptions.Value("AutoFitColumnWidth") = True
        ' export the Partslist to Excel with options
        oPartslist.Export(fileName, PartsListFileFormatEnum.kMicrosoftExcel, oOptions)
        PartsListNumber = PartsListNumber + 1
    Catch ex As Exception
        'MsgBox(String.Format("could not export partslist on sheet: {0} ({1})", Sheet.Name, ex.Message))
    End Try
Next
Regards
Alan
Message 3 of 12
eladm
Hi
Thanks' a lot ,but
If we have more than 1 part list in a sheet (inventor), in the excel we have only the 1st part list and not the other
After change the part list ,( add or remove column )it don't update the excel or skip a sheet in a drawing
Message 4 of 12
A.Acheson
Your original code has a for loop for partslist place that instead of
Regards
Alan
Message 5 of 12
eladm
sorry , I didn't understand
the rule I attached create for each part list an Excel file , (even if I have couple of part list in one Inventor drawing sheet)
I need all the part lists in the file to one excel file
Message 6 of 12
A.Acheson
Delete this line which is a direct reference to the first partslist object on this sheet
Rearrange the object looping like this. The for each oPartList  will find every partslist object on that sheet and carry out any operation in that loop.
'***********Paste in the rest of the code********
Next
Next
 When you have that done test and reply back with any issues you have.
Regards
Alan
Message 7 of 12
eladm
Sorry , the 1st - delete the line - understand
I didn't understand what to do the 2nd - rearrange
regards
Message 8 of 12
A.Acheson
Here is the working rule with added launch excel workbook at the end of the rule.
    Else
        Exit Sub
Else
Dim startRow = 1
For Each sheet As Sheet In oSheets 'Find every sheet in the drawing
	For Each oPartslist In Sheet.PartsLists 'Find every partslist on the sheet
	Next
Next
	Dim Complete = MessageBox.Show("All Done with Partslist Export" & vbCr & vbCr & fileName & vbCr & vbCr _
	& "Do you want to open the file?", "Part List Export", MessageBoxButtons.YesNo, MessageBoxIcon.Question, MessageBoxDefaultButton.Button1)
	If Complete = vbYes Then
        ThisDoc.Launch(fileName)
    Else
        Return
Regards
Alan
Message 9 of 12
eladm
The rule bring only
description , Part number and QTY
no other column
If one of the column is missing - error in line 51,
Message 10 of 12
A.Acheson
The column titles are optional. either place in all the column titles that you want to show up and exist in all PartsList or comment it out and all columns will be exported
       ' oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
Regards
Alan
Message 11 of 12
eladm
After add the column - I still get an error , line 51
But , why I need to specified the column ? not good
Message 12 of 12
A.Acheson
If all of the partslist column headers are not the same then you will continue to receive the error. Please remove or comment the option for exported columns. If the issues still persist, can you please provide the error message and indicate where the error is. I am still using INV 2020 which has no line numbers.
    Else
        Exit Sub
Else
Dim startRow = 1
        'specify the Columns To export(all columns need to be in the partslist)
        'oOptions.Value("ExportedColumns") = "QTY;PART NUMBER;DESCRIPTION"
	Next
Next
    Else
        Return
Regards
Alan
