Export 3DPDF using Anark does not seem to work with C# language
montanceslouis
montanceslouis
Hello and Good day,
I'm using C# and trying to invoke the api for exporting 3dpdf using Anark Core, but i'm having this error at "pdfConvertor3d.Publish(oDoc, oOptions);" please see image below:
The code provided from your API help was working fine using Visual Basic.
Is there a direct Inventor API to do 3dpdf export? The 3rd party app Anark don't seem to work using C#, not so sure.
Thank you! in advance for your feedback.
JelteDeJong
I don't think the problem is C#. In the help files, there is a C# example on how to export 3D pdf files.
public void Export3DPdf()
            Inventor.Application InvApp = mApp;
            Inventor.ApplicationAddIn  PDFAddin = null ;
            foreach (ApplicationAddIn appAddin in mApp.ApplicationAddIns )
                if (appAddin.ClassIdString == "{3EE52B28-D6E0-4EA4-8AA6-C2A266DEBB88}")
                    PDFAddin =  appAddin;
                    break;
            dynamic pdfConvertor3d = PDFAddin.Automation;
            Document oDoc = mApp.ActiveDocument;
            // Create a NameValueMap object
            Inventor.NameValueMap oOptions = InvApp.TransientObjects.CreateNameValueMap();
            oOptions.Value["FileOutputLocation"] = @"c:\temp\3DPDF.pdf";
            oOptions.Value["ExportAllProperties"] = true;
            oOptions.Value["GenerateAndAttachSTEPFile"] = true ;
            oOptions.Value["ExportTemplate"] = @"C:\Users\Public\Documents\Autodesk\Inventor 2019\Templates\Sample Part Template.pdf";
            oOptions.Value["VisualizationQuality"] = AccuracyEnum.kHigh;
            //string[] sProps = new string[1];
            //sProps[0] = "{F29F85E0-4FF9-1068-AB91-08002B27B3D9}:Title";
            //oOptions.Value["ExportAllProperties"] = false;
            //oOptions.Value["ExportProperties"] = sProps;
            String[] sDesignViews = new string[] { "Master", "View1" };
            oOptions.Value["ExportDesignViewRepresentations"] = sDesignViews;
In your code, I see some other options. Maybe one of those is the problem. Can you try to use only the options that are also in the help file?
Jelte de Jong
Blog: hjalte.nl - github.com
montanceslouis
Thank you for your input.
Yes, this code works fine on standalone project. As well as the visual basic.
But on over the Addin, the C# code is not working, only the visual basic.
By the way, the project that i'm doing is a separate addin for Inventor.
Thanks again, JelteDeJong
