Export 3D PDF with multiple/all design views?
claudio.ibarra
claudio.ibarra
Both of the example 3D PDF ilogic rules I can find have a similar bit of code where they only use one design view.
' Export Current design view
Dim sDesignViews(0) As String
sDesignViews(0) = oDocument.ComponentDefinition.RepresentationsManager.ActiveDesignViewRepresentation.Name
oOptions.Value("ExportDesignViewRepresentations") = sDesignViews
 and
    ' Set the design view(s) to export - note here I am exporting only the active design view (view representation)
What would the code look like if I want the 3D PDF to show all the design views and not just the current one?
Is it possible to show the user a list and have them check off the ones they want to include?
The sample code in the API help gives me an answer if I already know how many views there are and what the views are called, but is it possible to do this in a generic way that captures all the views regardless of how many there are or their names?
   ' Set the design views to export
    Dim sDesignViews(1) As String
    sDesignViews(0) = "Master"
    sDesignViews(1) = "View1"
KKizildemir
Hi @claudio.ibarra
Please change this piece of code with that:
	'  the design views to export
	Dim oCompDef As Inventor.ComponentDefinition = oDocument.ComponentDefinition
	Dim p, q, r As Integer
	q = oCompDef.RepresentationsManager.DesignViewRepresentations.Count
	Dim sDesignViews(q) As String
	For p = 1 To q
		r = p-1
		sDesignViews(r) = oCompDef.RepresentationsManager.DesignViewRepresentations.Item(p).Name
	Next
I hope this will help you.
Signature
website
emailskypelinkedinyoutubeemail
claudio.ibarra
Thank you very much! That worked perfectly.
KKizildemir
You're welcome! Have a nice day!
Signature
website
