Execute the external rule based on the opened Document
leebrg
leebrg
I have written an ilogic code to open a specific assembly.
Select A in the form inside the assembly called blankassy.iam
and run the code to get the assembly A.iam.
I want to get it and execute the 'TestRule' external rule based on A.iam.
The code below is the completed code so far.
However, the external rule is executed based on blankassy.iam, not A.iam.
I want to execute the external rule based on the opened A.iam.
Does anyone know how to solve this?
Thank you in advance.
Sub Main
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim TYPE As String = Parameter("TYPE")
Dim modPath As String
If TYPE = "A" Then
modPath = "C:\Temp\A.iam"
Else if TYPE = "B" Then
modPath =  "C:\Temp\B.iam"
End if
Dim oDocument As AssemblyDocument = ThisApplication.Documents.Open(modPath, True)
oDocument.Activate()
iLogicVb.RunExternalRule("TestRule")
End Sub
Michael.Navara
You can use  iLogicVb.Automation.RunExternalRule instead of iLogicVb.RunExternalRule. This method allows you to specify document which is the active in context of the rule.
I recommend you to use ThisDoc.Document instead of ThisApplication.ActiveDocument because active document may not be the same as document passed in argument as shown below.
Sub Main
	Dim oDoc As AssemblyDocument = ThisDoc.Document' ThisApplication.ActiveDocument
	If TYPE = "A" Then
	Else If TYPE = "B" Then
	iLogicVb.Automation.RunExternalRule(oDocument, "TestRule")
End Sub
