Execute method when sheet size is changed in addin C#
I am trying to figure out how to execute a method in my addin when the sheet size in a drawing is changed. I tried it using the on change event, however that leads to some kind of loop (stack overflow) that I kind get out of.
Currently using Inventor 2019. Addin in C#.
This is the code that is stuck in a loop:
private void OnChange(_Document DocumentObject, EventTimingEnum BeforeOrAfter, CommandTypesEnum ReasonsForChange, NameValueMap Context, out HandlingCodeEnum HandlingCode)
UserInterfaceManager userInterfaceManager = Globals.invApp.UserInterfaceManager;
Document document = Globals.invApp.ActiveDocument;
DocumentTypeEnum documentType = document.DocumentType;
DrawingDocument drawingDocument;
Sheet sheet;
DrawingSheetSizeEnum sheetSizeEnumOld = DrawingSheetSizeEnum.kADrawingSheetSize;
if (BeforeOrAfter == EventTimingEnum.kBefore)
switch (documentType)
case DocumentTypeEnum.kDrawingDocumentObject:
drawingDocument = (DrawingDocument)document;
sheet = drawingDocument.ActiveSheet;
sheetSizeEnumOld = sheet.Size;
break;
if (BeforeOrAfter == EventTimingEnum.kAfter)
if (Properties.Settings.Default.ShowFullyConstraints == true)
showFullyConstraint.startMarking(DocumentObject, isSaving);
Ribbon drawingRibbon = userInterfaceManager.Ribbons["Drawing"];
RibbonTab ribbonTab = drawingRibbon.RibbonTabs["tab_dwg"];
RibbonPanel ribbonPanel = ribbonTab.RibbonPanels["Drawing_panel_dwg"];
DrawingSheetSizeEnum sheetSizeEnum = sheet.Size;
//This should later be placed in a method
if (sheetSizeEnumOld != sheetSizeEnum)
RevisionTable revisionTable = null;
foreach (Sheet sheetA in drawingDocument.Sheets)
try { revisionTable = sheetA.RevisionTables[1]; }
catch { }
if (revisionTable != null)
Point2d revPt;
//Point2d borderPt;
TransientGeometry transientGeometry;
//borderPt = sheet.Border.RangeBox.MaxPoint;
transientGeometry = Globals.invApp.TransientGeometry;
revPt = transientGeometry.CreatePoint2d(sheetA.Border.RangeBox.MaxPoint.X - 1.085, 1 + (revisionTable.RangeBox.MaxPoint.Y - revisionTable.RangeBox.MinPoint.Y));
revisionTable.Position = revPt;
break;
HandlingCode = HandlingCodeEnum.kEventNotHandled;
What am I doing wrong here? How can I check if the sheet size has changed so I can execute some code?
