Excluding Print and Count if Sheet name matches
adeel.malik
Message 1 of 9
adeel.malik
I have a bunch of sheets named Vendor (e.g. Vendor:1 or Vendor:2...). For certain things I want to exclude these sheets from count and print. I wanted to write an ilogic for this but my code is not working.
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
i = 0
x = 0
For Each oSheet In oDoc.Sheets
	i = i + 1
Next
While (x<i)
	Sheet_Name = "Vendor:" & x
	x= x+1
	'ThisDoc.Document.Sheets.Item(Sheet_Name).ExcludeFromPrinting = True  <---Not working
	'ThisDoc.Document.Sheets.Item(Sheet_Name).ExcludeFromCount = True <---Not working
End While
Replies (8)
Message 2 of 9
A.Acheson
Does this work better for you?
Dim oDoc As DrawingDocument = ThisDoc.Document
Dim i as Integer = 0
For Each oSheet As Sheet In oDoc.Sheets
	i = i + 1
	If oSheet.Name = "Vendor:" & i
		oDoc.Sheets.Item(oSheet.Name).ExcludeFromPrinting = True
		oDoc.Sheets.Item(oSheet.Name).ExcludeFromCount = True
Next
Regards
Alan
Message 3 of 9
WCrihfield
Hi @adeel.malik.  This is just another example, very similar to the one posted by @A.Acheson, but includes a quick question, so you can use the same rule to toggle the sheets either way.  Then it is using the StartsWith() method, which can be useful in some situations.
Dim oDDoc As DrawingDocument = ThisDrawing.Document
Dim oExcludeVendorSheets As Boolean = InputRadioBox("Exclude Vendor Sheets?", "True", "False", False, "Toggle Vendor Sheets")
For Each oSheet As Sheet In oDDoc.Sheets
	If oSheet.Name.StartsWith("Vendor") Then
		oSheet.ExcludeFromCount = oExcludeVendorSheets
		oSheet.ExcludeFromPrinting = oExcludeVendorSheets
Next
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 9
adeel.malik
For some reason this doesn't work
Message 5 of 9
adeel.malik
Thankyou this is really helpful.
Message 6 of 9
A.Acheson
Just tested it now,  as the sheet name is found the sheet is excluded from the count and the sheet number drops. Therefore it will fail to catch all the sheets. This will work as well.
If oSheet.Name.Contains("Vendor") Then
Regards
Alan
Message 7 of 9
R_Cygan
That works rather well, I was wondering if we could reverse, the Code
Let's say we have 30 Sheets, but just few = 4 Sheets want send to Client,
Ideally The code would say:
If the Drawings is "Client" - Than Print Just "he "Client" Sheets,
otherwise Print All
No sure how that can work
Thank You for your Help
Message 8 of 9
WCrihfield
How do you plan on specifying or identifying which sheets are for "Client", and which are not?  Do those sheets have the word "Client" (or similar text) in their sheet name, or do you have some other way of identifying them?  When iterating through client sheets, do you really just want the code to immediately print each sheet that is for client, or just un-exclude them, exclude non-client sheets, then print all un-excluded sheets at the end?  If you would like one of us to create or modify a code to do what you want, then we would have to know all the details that you know about the task, because code usually needs to be extremely specific to work.  If searching for a String (text), then spelling, capitalization, and even empty spaces are important to have correct.
Wesley Crihfield
Message 9 of 9
R_Cygan
Thx,
I managed to Modify one Code from above and Works well,
The Rule Essentially will Isolate Sheets NOT Starting with "S"- To Print/ Export PDF as "Client drawings"
Not sure if this is Elegant, or "Proper" - but works - 100%
Thanks to that Chat Above!!
Dim oExcludeSheets As Boolean = InputRadioBox("Client or All Sheets?", "Client", "All", Client, "Toggle Sheets")
	If oSheet.Name.StartsWith("S") Then
		oSheet.ExcludeFromCount = oExcludeSheets
		oSheet.ExcludeFromPrinting = oExcludeSheets
Next
Please comment,
I appreciate
