Exception on AnalyzeInterference
Message 1 of 8
Just going through this and the below line is causing an exception in the tryAnalizeInterference method. I have put a counter and up to 5 objects no issues however beyond 5 it trips with the following exception.. Any idea what might be causing it?
Exception thrown: 'System.Runtime.InteropServices.COMException' in mscorlib.dll
DebugPluginLocally2.exe Error: 0 : Processing failed. System.Runtime.InteropServices.COMException (0x80004005): Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))
   at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   at Inventor.AssemblyComponentDefinition.AnalyzeInterference(ObjectCollection Set1, Object Set2)
   at SamplePlugin1.SampleAutomation.tryAnalizeInterference(Document doc, NameValueMap map)
adoc.ComponentDefinition.AnalyzeInterference(objs);
 private void tryAnalizeInterference(Document doc, NameValueMap map=null)
                        LogTrace("Processing " + doc.FullFileName);
                        try
                                if (doc.DocumentType != DocumentTypeEnum.kAssemblyDocumentObject) return;
                                var objs = _app.TransientObjects.CreateObjectCollection();
                                foreach (var item in doc.SelectSet)
                                        if (item is ComponentOccurrence co) objs.Add(co);
                                var adoc = doc as AssemblyDocument;
                                if (adoc == null) return;
                                if (objs.Count == 0)
                                        var count = 0;
                                        foreach (var item in adoc.ComponentDefinition.Occurrences)
                                                        objs.Add(item);
                                                        LogTrace($"count={count},       {co.Name}");
                                                        count++;
                                                if (count > 200) break;
                                var interfs = adoc.ComponentDefinition.AnalyzeInterference(objs);
                                if (interfs.Count == 0) return;
                                var hs1 = adoc.HighlightSets.Add();
                                hs1.Color = _app.TransientObjects.CreateColor(255, 0, 0);
                                var hs2 = adoc.HighlightSets.Add();
                                hs2.Color = _app.TransientObjects.CreateColor(0, 255, 0);
                                foreach (var interf in interfs)
                                        hs1.Clear();
                                        hs2.Clear();
                                        hs1.AddItem(interf);
                        catch (Exception e)
                                LogError("Processing failed. " + e);
Replies (7)
Message 2 of 8
I have tested the code below with the latest samples from here and the exception is only relevant to the 'InkJet printer' assembly where it has about 115 component occurences. Tried with other assysand no issues thus far but the other only have less than 21 compoccurs...
So it seems the issue is with the inkjet printer assy, unfortunately i dont have the source code to step in to 😞
        try
                        var count = 0;
                                        objs.Add(item);
                                        count++;
                        var item = interf as InterferenceResult;
                        hs1.AddItem(item.OccurrenceOne);
                        hs2.AddItem(item.OccurrenceTwo);
        catch (Exception e)
Message 3 of 8
The code below was tested against the latest samples from here. It seems only the Inkjet printer assembly is causing the exception. What exactly is causing it?
        try
                        var count = 0;
                                        objs.Add(item);
                                        count++;
        catch (Exception e)
Message 4 of 8
samples from here
Message 5 of 8
HideoYamada
I opened "Inkjet Printer Prototype.iam" and run your last code.
It doesn't cause exception.
The log output was...
Processing <<My working directory>>\Inkjet Printer Prototype\Workspace\Inkjet Printer Prototype.iam
count=0, Printer Frame:1
count=1, Main Roller:1
count=2, Cartridge Rail:1
count=3, Cartridge Stop:1
count=4, Main Roller Cap L:1
count=5, Main Roller Cap R:1
...Omission...
count=110, JIS B 1122 - C-Z ST3.5 x 13 - C - Z:1
count=111, JIS B 1122 - C-Z ST3.5 x 13 - C - Z:2
count=112, JIS B 1122 - C-Z ST3.5 x 13 - C - Z:3
count=113, JIS B 1122 - C-Z ST3.5 x 13 - C - Z:4
count=114, Paper Holder Stage 2:1
Is something different with you?
My system is...
* Windows 10 Pro ver. 1903 Japanese
* Inventor Pro 2020.1 + Japanese Language Pack
Freeradical
 Hideo Yamada
Freeradical
 Hideo Yamada
https://www.freeradical.jp
Message 6 of 8
HideoYamada
Oh, should I select something before executing the code?
Freeradical
 Hideo Yamada
Message 7 of 8
yeah, you need to select an assembly file, or perhaps a part file, check my code mate, just finished a bottle of strong wine, so cannot pinpoint, but the issue was only with the Inkjet printer, oh yeah, iam file. down load it from the link i mentioned.
Message 8 of 8
Hi Hideo,
Thanks so much for investigating....
for some reason i didnt get a notification for your replies hence the late response!
All seems to be working well this morning on the same code and same input file however different windows session and inventor session so one of them may have cleared up the issues.
next time i will do those two steps before i sound the alaram.
thanks bud!
