Exception from HRESULT
farshidDWRFR
Message 1 of 12
farshidDWRFR
Hi all,
I get the error message "Unspecified error (Exception from HRESULT: 0x80004005 (E_FAIL))" when running the following iLogic snippet. Can anyone please help me?
Dim oAsmDoc As AssemblyDocument = ThisDoc.Document
Dim oAsmCompDef As AssemblyComponentDefinition = Nothing
oAsmCompDef = oAsmDoc.ComponentDefinition
Dim oOcc As ComponentOccurrence
    For Each oOcc In oAsmCompDef.Occurrences
    	If oOcc.Visible = False Then
			oOcc.Definition.BOMStructure = BOMStructureEnum.kPhantomBOMStructure
	Next
Replies (11)
Message 2 of 12
aelqabbany
The script ran fine for me. I've made a few changes to make it more robust. If you run into any errors, please upload a screenshot of the details of the error dialog.
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As  AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
For Each oOcc As ComponentOccurrence In oAsmCompDef.Occurrences
		Try
			oOcc.Definition.BOMStructure = BOMStructureEnum.kPurchasedBOMStructure
		Catch
			MessageBox.Show("Could not set " & oOcc.Name & " to phantom", "Error", MessageBoxButtons.OK, MessageBoxIcon.Hand, MessageBoxDefaultButton.Button1)
		End Try
Next
Message 3 of 12
farshidDWRFR
Hello and thanks very much for your response.
I need the rule to set the suppressed components in an assembly to phantom, so they are not shown in the Bill of Materials with quantity 0. However, the code does not do this but gives an error message saying "Could not set ...to phantom.". I will appreciate it if you can help me fix this.
Message 4 of 12
aelqabbany
Thank you for clarifying. Give this a shot and let me know if you run into any issues:
	'Check if Occurrence is suppressed
	If oOcc.Suppressed = True Then
		Try
			'Unsuppress Occurrence
			oOcc.Unsuppress()
			'Set Occurrence BOM structure to Phantom
			'Suppress Occurrence without saving
			oOcc.Suppress(True)
		Catch
		End Try
Next
Message 5 of 12
farshidDWRFR
Hello again and thanks for your response.
The only part of the code that works properly is the message box. It does not perform the main job which is changing the BOM structure to Phantom.
Any suggestions?
Message 6 of 12
aelqabbany
Thank you for the feedback.
The only way I would be able to help you further, is if you were able to upload you working file, or at the very least upload detailed screenshots.
Message 7 of 12
farshidDWRFR
Is that fine if I send you a compressed file via a OneDrive link? My assembly folder is as large as 13.4G.
Message 8 of 12
aelqabbany
Sure. Please send it to me at abdullah[dot]elq[at]gmail[dot]com.
Or you can share the link here if you want others with more experience to take a look at it.
Message 9 of 12
WCrihfield
Hi @farshidDWRFR & @aelqabbany .  Just a couple quick notes...you can just set the BOMStructure of the ComponentOccurrence object directly (ComponentOccurrence .BOMStrucure), instead of trying to set the BOMStructure of the component's definition.  That might help eliminate some complications.  Also, keep in mind that if you are toggling component suppression status, there will need to be either a LevelOfDetailRepresentation (pre 2022) or a ModelState (2022 and later) involved, to record those status changes.
Wesley Crihfield
(Not an Autodesk Employee)
Message 10 of 12
aelqabbany
Thank you @WCrihfield. Your knowledge is always appreciated.
Message 11 of 12
farshidDWRFR
I just emailed you the download link.
Message 12 of 12
farshidDWRFR
Thanks, @WCrihfield for your advice.
