Exception from HRESULT: 0x80070057 (E_INVALIDARG) on Export IDW to DWG
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I'd like to know why code 'Save as DWG Translator Sample' from the Inventor API Help (see below the iLogic edition) generates Exception from HRESULT: 0x80070057 (E_INVALIDARG) on the attached IDW?
' Public Sub PublishDWG()
    ' Get the DWG translator Add-In.
    Dim DWGAddIn As TranslatorAddIn = ThisApplication.ApplicationAddIns.ItemById("{C24E3AC2-122E-11D5-8E91-0010B541CD80}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DWGAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        Dim strIniFile As String
        strIniFile = "C:\temp\DWGOut.ini"
        ' Create the name-value that specifies the ini file to use.
        oOptions.Value("Export_Acad_IniFile") = strIniFile
    'Set the destination file name
    oDataMedium.FileName = "c:\tempdwgout.dwg"
    'Publish document.
    Call DWGAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) ' The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
' End SubPS:
Dear @MjDeck could you, please, study this?
PS:
The issue was reproduced on Inventor 2024.3.3 and 2025.2.1.
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
Have tried to debug original VBA edition*:
Any hint regarding what to look at?
Can the issue be because of no "C:\temp\DWGOut.ini" file on my PC?
Should it be there?
I believe there is a typo in destination file name line ("\" is skipped) yet it is not the reason of the issue.
Maxim-CADman77
Solution is here
Maxim-CADman77
I wonder why export of 3Dmodel to DWG does not require an ini file?
MjDeck
Hi @Maxim-CADman77 - export of a 3D model to a DWG does not produce a full drawing. It makes a DWG file that contains solids, surfaces, and/or sketches. You can see this in the Inventor UI.
If you export a drawing to DWG, you will see a sequence of two dialogs with options. On the second dialog, you can save the options to an ini file. That's the same file that can be used by the API. Most of its options have to do with drawings.
If you use the UI to export a part or assembly to DWG, you don't see those options. All you see is checkboxes for Solids, Surfaces, and Sketches and the AutoCAD version.
When you export a part or assembly by the API, the "Export_Acad_IniFile" is just ignored. But you can set the other options as shown here:
https://modthemachine.typepad.com/my_weblog/2011/05/saving-3d-dwg-using-the-dwg-translator.html
and here:
https://adndevblog.typepad.com/manufacturing/2016/07/configure-options-of-saveas-dwg-of-part-or-asse...
Those are pretty old examples. To output with the latest supported version of AutoCAD, just leave out the "DwgVersion" option or (for Inventor 2025) set
oOptions.Value("DwgVersion") = 33
Mike Deck
Software Developer
Autodesk, Inc.
