Excel LookUp problems
Hello ALL! I need your help guys!!!!
Please see script below and attached spreadsheet. If parameter DisBeamOffset doesn`t match any of numbers from spreadsheet,  inventor gives me an error:
Excel cell not found (bad cell address?): "B-1"
NUM=GoExcel.CellValue("B" & CStr(GoExcel.FindRow("c:\Work12\Designs\ILOGIC\iDropOverFrame\drop over common parts.xls", "Sheet1", "DISCHARGE", "=", DisBeamOffset)))
FILENAME="c:\Work12\Designs\PARTS\PARTS - T\T37000-T37999\" & NUM & ".ipt"
Component.Replace("Sheet1", FILENAME, True)
Component.Replace("Sheet2", FILENAME, True)
How to handle this? Is there any chance to change script and catch the error?
Thanks much!
Vladimir.Ananyev
If parameter DisBeamOffset doesn`t match any of numbers from spreadsheet, iLogic function GoExcel.FindRow returns -1.
Sample code below use this fact to handle this situation.
'LookUp value
DisBeamOffset = 43  'this value doesn’t exists
Row = GoExcel.FindRow("drop over common parts.xls", _
MsgBox(Row)
If Row >=1  Then
NUM = GoExcel.CellValue("B" & CStr(Row))
    MsgBox(NUM)
Else
    MsgBox("DisBeamOffset = " & DisBeamOffset & _
 "  was not found in Excel sheet")
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Thanks man! Spasibo!
