Excel isn't playing nice
Hello everybody,
I made a rule that extracts information from an Excel file, and it works great for everybody in our team, except for this 1 guy that uses Office 2013, whereas the rest of us use Office 2010. His Windows Task manager shows that every time he runs this rule, an additional EXCEL instance is opened and stays open. He gets 10-12 of these after a few hours. I have 1 or none at all.
Needless to say I'm looking for a way to close his excessive Excels excellently.
I tried using the line GoExcel.Close, to no avail. Here is the relevant code, if it can help:
SyntaxEditor Code Snippet
' --- Trouve la cellule contenant le Materiel actif
FichierExcel = "T:\Inventor Normand\Design Data\iLogic\Mat-Actif.xls"
Dim NumMateriel as String
Dim rowPN as Integer
For rowPN = 1 To 2000
 If (GoExcel.CellValue(FichierExcel, "Feuil1", "A" & rowPN)) = NomMaterielSeul Then
 NumMateriel = GoExcel.CellValue(FichierExcel, "Feuil1", "B" & rowPN)
 iProperties.Value("Custom", "NumMateriel") = NumMateriel
 iProperties.Value("Project", "Description") = NomMaterielSeul
  'Info1 = GoExcel.CellValue("C" & rowPN)
    Exit For
  ' ElseIf NumMateriel = ""'  Exit Sub
Next
'GoExcel.Close Commented out, but does nothing if re-inserted
If NumMateriel = Nothing Then MessageBox.Show("Le materiel actif n'existe pas dans la librairie des materiaux." & vbLf & _ "SVP choisir un materiel dans la liste en haut.", "Erreur - iLogic" End If
Thank you to any and all who chime in to help.
Owner2229
Hi, try it like this below. The "NomMaterielSeul" variable is not declared in this rule, so i assume you have it declared somewhere outside of this code, right? If not, do so.
The changes are red highlighted.
GoExcel.Open("T:\Inventor Normand\Design Data\iLogic\Mat-Actif.xls", "Feuil1")
Dim NumMateriel As String
Dim rowPN As Integer
    If GoExcel.CellValue("A" & rowPN) = NomMaterielSeul Then
        NumMateriel = GoExcel.CellValue("B" & rowPN)
        Exit For
Next
GoExcel.Save
GoExcel.Close
    "SVP choisir un materiel dans la liste en haut.", "Erreur - iLogic")
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Hi Owner2229,
thank you for your response, but I get the error : "Server has generated an exception: (Exception from HRESULT: 0x80010105 (RPC_E_SERVERFAULT))"
I see what you did, but I don't see how this would avoid opening extra Excel instances. If anything, it made me open more instances of Excel as well, whereas I did not have this problem before. Weird.
I'll keep digging and playing with it a bit. I'll post any improvement I make.
Owner2229
Hi, try to run this first:
GoExcel.Close
And if it runs without issues, try this one to see where is the problem:
Try Dim NumMateriel As String Dim rowPN As Integer For rowPN = 1 To 2000 If GoExcel.CellValue("A" & rowPN) = NomMaterielSeul Then NumMateriel = GoExcel.CellValue("B" & rowPN) iProperties.Value("Custom", "NumMateriel") = NumMateriel iProperties.Value("Project", "Description") = NomMaterielSeul Exit For End If Next
Catch ex As Exception
MsgBox(ex.Message) End Try
GoExcel.Save GoExcel.Close
If not, try it like this:
Try
    GoExcel.Close
    MsgBox(ex.Message)
End Try
Mike
Here's what I've found:
GoExcel.Close works perfectly.
GoExcel.Open ("Filename.xls", "SheetName") does not.
I have to use a declared variable and use it to dig into the Excel file. For example, this works fine:
GoExcel.CellValue(FichierExcel, "Feuil1", "A" & rowPN) = NomMaterielSeul
This does not:
I keep getting the server error as described in a previous post. Apparently this has to do with how Excel 2013 deals with multiple instances of itself (MDI) vs the  2010 version (SDI). I'm waiting a call from a service tech who should tell me how to make Excel 2013 act like it's 2010.
The soggy saga continues....
Owner2229
Alright then, can you try this one instead? It might help as it is ussing a bit different approach to the document.
excelApp = CreateObject("Excel.Application")
excelApp.Visible = False
excelApp.DisplayAlerts = False
excelWorkbook = excelApp.Workbooks.Open("T:\Inventor Normand\Design Data\iLogic\Mat-Actif.xls")
excelWorkbook.Save
excelWorkbook.Close
Here is how to use it to write data.
Remember that in this method is row first and column second. And you don't reffer to columns with letters, but with numbers (their possition). So, (5, 4) is "D5"
Dim oExcel As Object = CreateObject("Excel.Application")
oExcel.Visible = False
oExcel.DisplayAlerts = False
Dim oWB As Object = oExcel.Workbooks.Open("T:\Inventor Normand\Design Data\iLogic\Mat-Actif.xls")
Dim oWS As Object = oWB.Sheets(1)
oWS.Cells(5, 4).Value = "some text"
oWS.Cells(7, 4).Value = "more text"
oWS.Cells(8, 4).Value = "even more text?"
oWB.Save
oWB.Close (True)
oExcel.Quit
Mike
