This is a repost from https://forums.autodesk.com/t5/configurator-360-forum/event-triggers-not-firing-in-top-level-assembl... and I attached the bare bone (.zip) model I talk about below. I know configurator 360 uses Inventor Server so anywhere I say C360 just imagine I said Inv Server. If anyone out there can help me figure this out I'm getting desperate.
Once upon a time in a land of innocence, I used to trigger rules in my top-level assembly by offsetting a plane by a distance set in my skeletal model. When the skeleton would change the parameter would update and the "Any Model Parameter Change" event would fire my rule. (This story probably sounds like one you've heard me tell before; Same story different day)
I stripped my scenario down to the bare bones.
https://configurator360.autodesk.com/125106773177157182/thcsr5q4ykx8 I have one parameter in a, new from scratch, skeleton that has a multi value of 1 thru 4. I have one part in a, new from scratch, .iam, a plane offset from origin, and a rule that toggles visible/exclude set to run on parameter change (it doesn't care what has changed just that something has changed.) It works just as I would expect in Inv 2018 but does nothing in C360. Oddly in the model I care about the sub parts are set to run the same way and work but when I put my new single part assembly in another assembly it still doesn't fire (in C360)
I have been fighting this since July 9th. Why doesn't this work anymore? No event triggers I set with the event triggers dialog trigger anymore. Did something change in the last 4 months? I know C360 was updated to 2020 and support was dropped for 2017 and older but why do my old saved files work and new saved files don't?
Mass Override for Each Model State
Custom Glyph Icon for iMates
