Event Trigger after open document
blandb
Mentor Mentor
blandb
I have a very simple rule that appeared to work on "new Document", but doesn't seem to work on "After open document". It is a multivalue set list.
Here is the rule:
MultiValue.SetList("CUSTOMERS", "cust a", "cust b", "cust c")
If I have this run under new doc and after open, all seems to be ok, but if I remove it from new document and only have it under after open, nothing updates.....Any Ideas as to why?
Autodesk Certified Professional
A.Acheson
You may need to set the parameter value after changing changing the list. Or you can set the list to take on a value in the list. Check out this article here
MultiValue.SetValueOptions(True, DefaultIndex := 0, NumericCompare := “=”)
Regards
Alan
