Error with ilogic code
planner_mobbs_engineering
Could Anyone Please help me with this:
I Have created a code in sheet metal to trigger for maximum length and width just for documentation purposes.
But it says error in Line one of the code when I open the   document I do not understand why:
Parameter("FLAT_PATTERN_LENGTH") = SheetMetal.FlatExtentsLength
Parameter("FLAT_PATTERN_WIDTH") = SheetMetal.FlatExtentsWidth
A.Acheson
There may not be enough information provided to diagnose the issue. The ilogic snippet provided will create a flat pattern and give you the size of the flat pattern. Is there any errors preventing the flat pattern being created?
Can you attach the error messages including the more info message and also explain the exact steps causing the error.
An image can help as well.
Regards
Alan
