Error while using Inventor related to ilogic
Hello everyone,
While using Inventor 2018 , at the time of working it frequently pop for error message related to ilogic.
Please anybody here help me out to resolve this.
snapshot of error is attached for reference.
Vijendra S.
India.
Sergio.D.Suárez
Hi, apparently, inventor is not finding the external rule. Please check the routes of the external rules.
If the problem persists, if possible, attach the rule to analyze it.
Regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Jason.Rugg
@Anonymous If you have received the model/file from someone else and they did not include the external rule, use the iLogic browser to suppress or delete the rule from the model so it's not trying to run.
Sorry for late response.
I have tried using the given solution but not get resolve.
snapshot with model is attached for reference.
snapshot is attached for reference.
Hi jason,
1. Actually I have created that part by using the reference part given by someone.
2. after long search i finally found ilogic browser option there i clicked on Even Triggers  I have found it was setted (zoom fit) under certain i have selected the same and removed it.
now it works properly..
Thanks Jason for the solution.
But do we have any option so that i can eliminate this step for permanently.
because whenever i open the model if it shows this error i need to follow same procedure for that file too.
let me know if any
Jason.Rugg
@AnonymousIf you no longer need the rules/iLogic, just delete the rules out of the browser.
