error while sending parameters from assembly to parts
This is my code:
Public Sub Main()
          CopyUserParamsParts()
          CopyUserParamsAssies()
          iLogicVb.UpdateWhenDone = True
End Sub
Private Sub CopyUserParamsParts()
    If ThisDoc.Document.DocumentType <> Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
        MsgBox("The active document must be an assembly.")
        Return
    Dim asmDoc As Inventor.AssemblyDocument = ThisDoc.Document
    For Each refDoc As Inventor.Document In asmDoc.AllReferencedDocuments
           ' Look for part documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kPartDocumentObject Then
                       Dim oDoc As Inventor.Document = ThisDoc.Document
                       Dim partDoc As Inventor.PartDocument = refDoc
            Dim refDocUserParams As UserParameters = partDoc.ComponentDefinition.Parameters.UserParameters
                       ' skip Content Center files
                       If refDoc.PropertySets.PropertySetExists ("ContentCenter") = False Then
                    ' Add the assembly parameters to the part.
                    For Each asmUserParam As UserParameter In asmDoc.ComponentDefinition.Parameters.UserParameters
                        ' Check to see if the parameter already exists.
                        Dim checkParam As UserParameter = Nothing
                        Try
                            checkParam = refDocUserParams.Item(asmUserParam.Name)
                        Catch ex As Exception
                            checkParam = Nothing
                        End Try
                        If checkParam Is Nothing Then
                            ' Create the missing parameter.
						If asmUserParam.Units = "Text" Then
							refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, UnitsTypeEnum.kTextUnits)
						Else
                            refDocUserParams.AddByExpression(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
                        Else
                            ' Update the value of the existing parameter.
                            checkParam.Expression = asmUserParam.Expression
               Next
    Next
End Sub
Private Sub CopyUserParamsAssies()
        Return
           ' Look for assembly documents.
        If refDoc.DocumentType = Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
                       Dim AssyDoc As Inventor.AssemblyDocument = refDoc
            Dim refDocUserParams As UserParameters = AssyDoc.ComponentDefinition.Parameters.UserParameters
                    ' Add the assembly parameters to the subasembly.
                        Try
                        End Try
						Else
						Else
               Next
    Next
End Sub
If I run this code on just normal user parameters, it works, but if I do this with Text parameters, it fails and gives me back error:
Error in rule: Push parameters V2, in document: autolift.iam
De parameter is onjuist. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Can anybody help me?
Sergio.D.Suárez
I am not sure what you are trying to do, but I would modify the code a bit to start working, I would leave it more or less like that.
Sub Main()
      Exit Sub
          CopyUserParamsToRefDoc()
End Sub
Sub CopyUserParamsToRefDoc()
		Dim refDocUserParams As UserParameters = refDoc.ComponentDefinition.Parameters.UserParameters
				Try
				Catch
					Try
					Catch
						refDocUserParams.AddByValue(asmUserParam.Name, asmUserParam.Expression, asmUserParam.Units)
					End Try
				End Try
			Next
	Next
End Sub
 I hope it works for what you need. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
