Error when round value to 2th decimal
Neuzzo
Neuzzo
Hi, I have a problem with this macro:
the final value of "iProperties.Value("Custom", "DCM_Laser")" I can't round it to the second decimal place: e.g. 0.00
When I try to add the (value, 2) in the expression I get this error:
Dim oDoc As Document = ThisApplication.ActiveDocument
	If Not oDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
		Exit Sub
	If Not oDoc.IsModifiable = True Then
		Exit Sub
	If Not oDoc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
		Exit Sub
Dim oSMDoc As PartDocument = ThisApplication.ActiveDocument
Dim oSMDef As SheetMetalComponentDefinition = oSMDoc.ComponentDefinition
If oSMDef.HasFlatPattern = False Then
	MsgBox("Manca il modello piatto.", vbOKOnly, "NO FLAT PATTERN")
	Exit Sub
Dim oCompOcc As ComponentOccurrence
	iProperties.Value("Custom", "DCM_Lamiera") = "T"
	Dim oTopFace As Face = oSMDef.FlatPattern.TopFace
	Dim oMeasureTools As MeasureTools = ThisApplication.MeasureTools
	Dim oLoopLength As Double = 0.00
		For Each oEdgeLoop As EdgeLoop In oTopFace.EdgeLoops
		oLoopLength = oLoopLength + oMeasureTools.GetLoopLength(oEdgeLoop)
	Next
If iProperties.Material = "801171 AISI 304 sp.1 2B"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/8,2)
	Else If iProperties.Material = "801181 AISI 304 sp. 1.2 2B"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/7.7)
	Else If iProperties.Material = "801211 AISI 304 sp. 2 2B"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/5)
	Else If iProperties.Material = "811151 AISI 304 sp. 0.8 SB + PVC"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/8.2)
	Else If iProperties.Material = "811175 AISI 304 sp. 1 SB + PVC"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/8)
	Else If iProperties.Material = "811181 AISI 304 sp. 1.2 SB + PVC"
	Else If iProperties.Material = "811191 AISI 304 sp. 1.5 SB + PVC"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/7)
	Else If iProperties.Material = "811194 AISI 304 sp. 2 SB + PVC"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/4.6)
	Else If iProperties.Material = "811196 AISI 304 sp. 3 SB + PVC"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/2.5)
	Else If iProperties.Material = "811501 AISI 430 sp. 3 BA"
	Else If iProperties.Material = "811525 AISI 430 sp. 0.8 BA"
	Else If iProperties.Material = "811531 AISI 430 sp. 0.8 SB + PVC"
	Else If iProperties.Material = "811535 AISI 430 sp. 0.8 SB + PVC"
	Else If iProperties.Material = "811541 AISI 430 sp. 1 SB + PVC"
	Else If iProperties.Material = "811547 AISI 430 sp. 1 BA"
	Else If iProperties.Material = "811583 AISI 430 sp. 1.5 BA"
	Else If iProperties.Material = "811585 AISI 430 sp. 1.5 BA + PVC"
	Else If iProperties.Material = "811587 AISI 430 sp. 2 BA"
	Else If iProperties.Material = "811813 ALLUMINATA sp. 0.8"
	Else If iProperties.Material = "811817 ALLUMINATA sp. 1"
	Else If iProperties.Material = "811819 ALLUMINATA sp. 1.5"
	Else If iProperties.Material = "811823 ALLUMINATA sp. 2"
	Else If iProperties.Material = "811931 Fe sp. 2"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/5.5)
	Else If iProperties.Material = "811937 Fe sp. 3"
		iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/4)
	Else If iProperties.Material = "811939 FE-ZINCATO sp. 2"
	Else If iProperties.Material = "811941 FE-ZINCATO sp. 3"
How can I solve it? Thank you
Danilo "DannyGi" G.
Mechanical design engineer and product developer
CattabianiI
try this one:
iProperties.Value("Custom", "DCM_Laser") = Round((oLoopLength/100)/8, digits := 2)
Neuzzo
It work. Thank you
Danilo "DannyGi" G.
