Error when creating drawing file fromout assembly
Daan_M
Daan_M
When i try to create a drawing with iLogic, Inventor keeps throwing errors.
I'm kinda tired so might be missing something obvious, but i don't understand what's wrong with the code
Sub Main()
Dim oInvApp As Inventor.Application = ThisApplication
Dim oDoc As Inventor.Document = ThisDoc.Document
Dim oDocDir As String = ThisDoc.Path & "\"
Dim oDocName As String = ThisDoc.FileName
Dim oTemplate As String = "X:\CAD 3D\Testmap\Template\Template sales tekening.idw"
Dim oDrawingDoc As DrawingDocument = oInvApp.Documents.Add(kDrawingDocumentObject, oTemplate, True)
oDrawingDoc.SaveAs(oDocDir & oDocName & ".idw" ,True)
oDrawingDoc.Close
End Sub
Daan_M
Managed to find the problem:
I had my template file open in the same instance of the Inventor application, this caused an Error without further explanation: The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Kinda annoying tbh, but still my fault.
Funnily enough opening the file works;
oInvApp.Documents.Open(oTemplate)
But adding it as new drawing DOESNT
oInvApp.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, oTemplate, True)
