Error trying to close the .iam
jcorrero87
jcorrero87
Hello everyone,
Creating a macro to close the set if a password is not introduced. A problem arose when executing "Thisapplication.document.closeall", error 438 arises. Can anyone tell me that I am doing wrong?.
The macro is as follows:
Public Sub Doc_c()
If Date <= DateSerial(2022, 11, 20) Then GoTo fin
On Error GoTo Ver_Error
licenciauso = InputBox("Enter the usage password")
If licenciauso <> "password" Then
MsgBox "Incorrect password"
ThisApplication.Document.CloseAll
GoTo fin
Ver_Error:
fin:
End Sub
Thank you so much.
ciaran.gibson
Error 438 typically occurs when you try to access an object or property that does not exist or is not valid. In this case, it's possible that the issue is caused by the use of ThisApplication.Document.CloseAll.
try this:
Public Sub Doc_c()
' Check if the current date is on or before November 20, 2022
' If an error occurs, jump to the Ver_Error section
' Prompt the user to enter the usage password
' If the password is incorrect, show an error message and close all open documents
Application.Documents.CloseAll
Exit Sub ' Exit the subroutine to prevent further execution
fin:
' This is the end of the subroutine
End Sub
Michael.Navara
Perhaps it is a typo at line
it should be
ThisApplication.Documents.CloseAll
jcorrero87
Thank you very much for the help
