Error on iLogic code - not obvious how to fix
RNDinov8r
RNDinov8r
Here is the code i have. I have commented out the error that I get when I go to run it. The intent is to run some iLogic to delete suppressed parts and assembly after running a form where the user would choose which options to include. Those options not used, would be suppressed, and then ultimately deleted.
Sub Main()
  Dim doc As AssemblyDocument
  doc = ThisApplication.ActiveDocument
  Dim acd As AssemblyComponentDefinition
  acd = doc.ComponentDefinition
  Call DeleteSuppressedComponent(acd.Occurrences)
End Sub
Sub DeleteSuppressedComponent(occs As ComponentOccurrences)
  Dim occ As ComponentOccurrence
  For Each occ In occs
     If occ.Suppressed Then
         occ.Delete
     Else
         Call DeleteSuppressedComponent(occ.SubOccurrences)
   Next
End Sub
'System.ArgumentException: The Parameter Is incorrect. (Exception From HRESULT: 0x80070057 (E_INVALIDARG))
   'at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32[] aWrapperTypes, MessageData& msgData)
   'at Inventor.ComponentOccurrence.Delete()
   'at ThisRule.DeleteSuppressedComponent(ComponentOccurrences occs)
   'at ThisRule.Main()
   'at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   'at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
DRoam
I was able to get this error by running your code on an assembly where an occurrence within a component pattern was suppressed. Could that be the issue for you?
If so, you could solve the issue by making sure the suppressed occurrence is not part of a pattern, and if it is, leave it alone. This tweak will do that:
	If Not occ.IsPatternElement Then
		occ.Delete
Else
RNDinov8r
That looks like it. I had inadvertantly suppressed a part in a pattern. Thanks for the help
