Error on custom made rectangle program
Mehmet_Fatih_Turker
Message 1 of 16
Mehmet_Fatih_Turker
AddReference "System.Drawing"
AddReference "Microsoft.Office.Interop.Excel"
Imports System.Drawing
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.Office.Interop.Excel
Imports System.Runtime.InteropServices
Sub Main()
    ' Define the list to store rectangle dimensions
    Dim rectangles As New List(Of Tuple(Of Double, Double))
	Dim RectNo As Byte = 1
    Dim length As Double
    Dim width As Double
	Dim oPartCompDef As PartComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oPartCompDef.WorkPlanes.Item(3))
	Dim oOriginPoint As SketchPoint
	Dim oRectangleLines = oSketch.SketchLines
    Dim prevWidth As Double = 0 ' Initialize the previous rectangle's dimensions
		Do
			done = GetRectangleDimensions(RectNo, prevWidth, length, width)
			If done Then Exit Do ' Exit the loop if the user finishes input
	        rectangles.Add(Tuple.Create(length, width)) ' Add the valid rectangle dimensions to the list
			prevWidth =width
		    RectNo += 1
		Loop Until done
	ShowRectangleList(rectangles)
    For Each rect In rectangles
		DrawRectangle(oSketch, rect.Item1, rect.Item2)
		ApplyDimsofRectangles(oSketch, oRectangleLines)
    	oOriginPoint = CheckOriginSketchPoint(oPartCompDef, oSketch)
    	CoincidentConstraint(oMidSketchPoint, oOriginPoint, oSketch)
    Next
End Sub
Function GetRectangleDimensions(RectNo As Byte, prevWidth As Double, ByRef length As Double, ByRef width As Double) As Boolean
	Dim done As Boolean = False
	'get length with validation
	length=GetValidatedInput("Ener the length of the" &RectNo.ToString()& "rectangle (or type 'd' to finish)","Rectangle", done)
	If done Then Return True
		width = GetValidatedInput("Enter the width of the " & RectNo.ToString() & " rectangle (or type 'd' to finish)", "Rectangle", done) + prevWidth
	If done Then
        MessageBox.Show("You can't finish without specifying the width for this rectangle!", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        Return False ' Prevent finishing without width input
	Return False ' Continue the loop
End Function
Function GetValidatedInput(prompt As String, title As String, ByRef done As Boolean) As Double
    Dim validInput As Boolean = False
    Dim result As Double = 0
	Do
		Dim input As String = InputBox(prompt, title)
		If input.ToLower() = "d" Then
			done = True
			Exit Function 'return from the function if "d" is entered
        Try
            result = CDbl(input)
            validInput = True
        Catch ex As Exception
            MessageBox.Show("Invalid input! Please enter numeric values.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
        End Try
		Loop Until validInput
	Return result
End Function
Sub DrawRectangle(oSketch As PlanarSketch, length As Double, width As Double)
    Dim halfLength As Double = length / 20
    Dim halfWidth As Double = width / 20
    ' Validate dimensions
    If halfLength <= 0 Or halfWidth <= 0 Then
        MessageBox.Show("Invalid dimensions: length=" & length & ", width=" & width)
        Exit Sub
    ' Create points
    Dim centerPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, 0)
    Dim cornerPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(halfLength, halfWidth)
    ' Ensure points are valid
    If centerPoint Is Nothing Or cornerPoint Is Nothing Then
        MessageBox.Show("Invalid points: Center or Corner point is null")
        Exit Sub
    ' Add rectangle
    Try
        oRectangleLines = oSketch.SketchLines.AddAsTwoPointCenteredRectangle(centerPoint, cornerPoint)
        MessageBox.Show("Error adding rectangle: " & ex.Message)
    End Try
End Sub
Sub ApplyDimsofRectangles(oSketch As PlanarSketch, oRectangleLines As SketchLines)
    ' Extract the lines for dimensioning
	Dim oLine3 As SketchLine = oRectangleLines(3)
	Dim oLine2 As SketchLine = oRectangleLines(2)
	' Create valid Point2d objects for dimension text locations
	Dim oDimPositionHorizontal As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(0, oLine3.StartSketchPoint.Geometry.Y + 1)
    Dim oDimPositionVertical As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oLine2.StartSketchPoint.Geometry.X + 1, 0)
    ' Add dimension constraints to the rectangle 'oLine1.StartSketchPoint.Geometry.X + 1 'oLine2.StartSketchPoint.Geometry.Y + 10
	Try
         oSketch.DimensionConstraints.AddTwoPointDistance(oLine3.StartSketchPoint, oLine3.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, oDimPositionHorizontal)
        MessageBox.Show("Error adding horizontal dimension: " & ex.Message)
    End Try
    Try
         oSketch.DimensionConstraints.AddTwoPointDistance(oLine2.StartSketchPoint, oLine2.EndSketchPoint, DimensionOrientationEnum.kVerticalDim, oDimPositionVertical)
        MessageBox.Show("Error adding vertical dimension: " & ex.Message)
    End Try
End Sub
Sub CoincidentConstraint(SketchPnt1 As SketchPoint, SketchPnt2 As SketchPoint, Sketch As PlanarSketch)
    Try
        Sketch.GeometricConstraints.AddCoincident(SketchPnt1, SketchPnt2)
        ' Handle the exception if needed
    End Try
End Sub
Function CheckOriginSketchPoint(CompDef As PartComponentDefinition, Sketch As PlanarSketch) As SketchPoint
    Dim OriginSketchPoint As SketchPoint = Nothing
    For Each pSketchPoint As SketchPoint In Sketch.SketchPoints
        If pSketchPoint.ReferencedEntity IsNot Nothing Then
            OriginSketchPoint = pSketchPoint
            Exit For
    Next
    If OriginSketchPoint Is Nothing Then
        OriginSketchPoint = Sketch.AddByProjectingEntity(CompDef.WorkPoints(1))
    Return OriginSketchPoint
End Function
Sub ShowRectangleList(rectangles As List(Of Tuple(Of Double, Double)))
    Dim rectangleListString As String = "Current list of rectangles:" & vbCrLf
        rectangleListString &= "Length: " & rect.Item1 & ", Width: " & rect.Item2 & vbCrLf
    Next
    MessageBox.Show(rectangleListString, "Rectangle List", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
Hi all is there anyone help me finding error here ? at the first rectangle everything works just fine but when program goes to second and third rectangle. it draws the rectangles but it just doesnt constrain and doesnt put dimension to sketch. Im probably got tired but I just cant see the error...
Thanks in advance
Replies (15)
Message 2 of 16
Mehmet_Fatih_Turker
Any help ?
Message 3 of 16
_dscholtes_
I'm pretty sure, those indexes (2 and 3) are not correct after adding your second rectangle. I expect it's using the same lines and location points to place the dimensions for each rectangle, therefore placing identical dimensions on top of each-other.
Message 4 of 16
J-Camper
@Mehmet_Fatih_Turker,
I tried not to modify the format too much, but the biggest issue I saw was you were treating non global variables as global.  I changed some of your sub routines to functions.  Try This:
Sub Main()
    Dim width As Double
	Dim oRectangleLines As SketchEntitiesEnumerator'= oSketch.SketchLines
	Dim oMidSketchPoint As SketchPoint
		Do
			Dim InputTuple As Tuple(Of Double, Double) = GetRectangleDimensions(RectNo)
			done = InputTuple Is Nothing
	        rectangles.Add(InputTuple) ' Add the valid rectangle dimensions to the list
		    RectNo += 1
		Loop Until done
		oRectangleLines = DrawRectangle(oSketch, rect.Item1, rect.Item2)
		Logger.Trace(oRectangleLines.Count)
		oMidSketchPoint = ApplyDimsofRectangles(oSketch, oRectangleLines)
    Next
End Sub
Function GetRectangleDimensions(RectNo As Byte) As Tuple(Of Double, Double)
	Dim Inputlength As Double = 0.0
	Dim Inputwidth As Double = 1.0
	Inputlength = GetValidatedInput("Ener the length of the" &RectNo.ToString()& "rectangle (or type 'd' to finish)","Rectangle", done)
	If Inputlength = 0 Then Return Nothing
	While Inputwidth <> 0
		Inputwidth = GetValidatedInput("Enter the width of the " & RectNo.ToString() & " rectangle (or type 'd' to finish)", "Rectangle", done) '+ prevWidth
		If Inputwidth <> 0 Then Exit While
	End While
	Return Tuple.Create(Inputlength,Inputwidth) ' Continue the loop
End Function
	Do
			done = True
        Try
            validInput = True
        End Try
	Return result
End Function
Function DrawRectangle(oSketch As PlanarSketch, length As Double, width As Double) As SketchEntitiesEnumerator
        Exit Function
    ' Create points
        Exit Function
    ' Add rectangle
    Try
        Return oSketch.SketchLines.AddAsTwoPointCenteredRectangle(centerPoint, cornerPoint)
		Return Nothing
    End Try
End Function
Function ApplyDimsofRectangles(oSketch As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator) As SketchPoint
	Try
    End Try
    Try
    End Try
	Return oSketch.SketchPoints.Item(oSketch.SketchPoints.Count)
End Function
    Try
    End Try
End Sub
            Exit For
    Next
End Function
    Next
End Sub
Message 5 of 16
Mehmet_Fatih_Turker
Hi @J-Camper
You have changed lots of think and it was very good for improving my skills. So thank you for that.
But another questions rises 🙂
 In here ApplyDimsofRectangles returns a point. But that should only to apply dimension on created rectangles(at least from my perspective). Could you please explain why did you use that function in this way, if possible ?
Why did you use this method ?
	Dim oRectangleLines As SketchEntitiesEnumerator = oSketch.SketchLines
Can I keep the rectangle lines as list in order to use it in different place ? Also, can I directly catch one of the lines center point in order to constrain to other point ?
Message 6 of 16
J-Camper
To answer your questions in order:
1. I made it return a point, but I changed how i got the point so it didn't really need to be that way.  My first plan was to return the midpoint of one of the construction lines created in the centerpoint rectangle command.  I changed my mind after setting up the sub as a function because the centerpoint rectangle command already creates a point there.  That point is not included in the SketchEntitiesEnumerator, it only contains the 6 sketchlines, so I'm instead getting the last sketchpoint that was created in the sketch and returning as midpoint.  Getting the last sketchpoint created in the sketch could have been retrieved outside of the function.
TLDR: It didn't need to be a function as i changed how I retrieved the midpoint, but had already set it up as a function.
2. The Logger.Trace("String here") creates and entry in the iLogic Log window.  I use this when debugging as it does not required closing a messagebox and you can copy paste out of the log window:
3. The Method used to create a rectangle returns an enumerator of sketchentities.  If you would like to keep a list of them, you can cast the enumerator into an IEnumerable and convert that to a list:
Dim LineList As List(Of SketchLine) = oRectangleLines.Cast(Of SketchLine).ToList()
You would have to keep a list of lists though since you are creating multiple rectangles.  Or you could add each list together into a single large list, depending on what your intention with those sketchlines is.
Let me know you you have any further questions, or if anything you want further explanation on any of my answers.
Message 7 of 16
J-Camper
Also if you are interested, I have attached a text file with more of the original rule layout changed.  I tried not to modify your original too much in my first post, but I would have gone about things differently if I was starting from scratch.
Message 8 of 16
Mehmet_Fatih_Turker
Hi @J-Camper Thanks for sharing. I'm also developing my code in order to get aligned with current design scenario.
Sub Main()
	If Not DocumentTypeValidation(ThisApplication) Then
        Exit Sub ' Exit the main subroutine if validation fails
	Dim oThisSession As Inventor.Application = ThisApplication
	Dim oPartCompDef As PartComponentDefinition = oThisSession.ActiveDocument.ComponentDefinition
	Dim asd As PlanarSketch
	Dim xprevOffset As Double = 0.0
	Dim yprevOffset As Double = 0.0
	Dim xprevHeight As Double = 0.0
	Dim yprevHeight As Double = 0.0
	Dim RectIndex As Byte = 1
	Do
		Dim InputTuple As Tuple(Of Double, Double) = GetRectangleDimensions(RectNo, done)
		If InputTuple Is Nothing Then
			Exit Do
		rectangles.Add(InputTuple)	' Add the dimensions to the list
		RectNo += 1
	Loop
	Dim oSketch As PlanarSketch = oPartCompDef.Sketches.Add(oPartCompDef.WorkPlanes.Item(3)) 'Create sketch after getting rect values
	Dim oOriginPoint as SketchPoint = CheckOriginSketchPoint(oPartCompDef, oSketch)
	Dim prevRectangleLines As SketchEntitiesEnumerator = Nothing ' To store the lines of the previous rectangle
	Dim prevMidOfThirdLine As SketchPoint = Nothing ' To store the midpoint of the third line of the previous rectangle
		Dim currentRectangleLines  = DrawRectangle(oSketch, rect.Item1, rect.Item2) ' Draw the rectangle using the dimensions
		ApplyDimsofRectangles(oSketch, currentRectangleLines, RectIndex, xprevOffset, yprevOffset, xprevHeight, yprevHeight)
    	Dim currentMidOfFirstLine = GetMidpointOfLinesMiddlePoint(oSketch, currentRectangleLines)
    	Dim currentMidOfThirdLine = GetRectThirdlineMidPoint(oSketch, currentRectangleLines)
		If RectIndex = 1 Then
        	' First rectangle: Constrain its first line midpoint to the origin
        	CoincidentConstraint(currentMidOfFirstLine, oOriginPoint, oSketch)
		Else
        	' Constrain the first line midpoint of the current rectangle to the third line midpoint of the previous rectangle
        	CoincidentConstraint(currentMidOfFirstLine, prevMidOfThirdLine, oSketch)
'		currentMidOfThirdLine = GetRectThirdlineMidPoint(oSketch, currentRectangleLines)
		prevMidOfThirdLine = currentMidOfThirdLine
		RectIndex += 1
    Next
	oThisSession.ActiveView.GoHome()
	oThisSession.ActiveDocument.save()
End Sub
Function GetRectangleDimensions(RectNo As Byte, ByRef done As Boolean) As Tuple(Of Double, Double)
    Dim Inputwidth As Double = 0.0
    ' Get length with validation
    Inputlength = GetValidatedInput("Enter the length of the " & RectNo.ToString() & " rectangle (or type 'd' to finish)", "Rectangle", done)
    If done Then Return Nothing ' Exit if the user finishes input during length entry
    Do
        ' Get width with validation, user cannot exit here
        Inputwidth = GetValidatedInput("Enter the width of the " & RectNo.ToString() & " rectangle ", "Rectangle", done)
        If done Then
            done = False ' Reset done flag so that the user cannot exit at this stage
        Else
            Exit Do ' Exit loop if a valid width is entered
    Loop
    Return Tuple.Create(Inputlength, Inputwidth)
End Function
    While Not validInput
            done = True
            Return 0 ' Return 0 or any default value if "d" is entered
        Try
            If result > 0 Then
                validInput = True ' Valid input only if it's positive
            Else
                MessageBox.Show("Value must be a positive number. Please enter a valid value.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
            MessageBox.Show("Invalid input! Please enter numeric values.", "Error", MessageBoxButtons.OKCancel, MessageBoxIcon.Error)
        End Try
    End While
    Return result
End Function
Function ApplyDimsofRectangles(oSketch As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator, RectIndex As Byte, ByRef xprevOffset As Double, ByRef yprevOffset As Double, ByRef xprevHeight As Double, ByRef yprevHeight As Double) As SketchPoint
	Dim oLine3 = oRectangleLines(3) ' Extract the lines for dimensioning
    Dim oLine2 = oRectangleLines(2) ' Extract the lines for dimensioning
	Dim xcurrentHeight = oLine3.Length ' Current rectangle's height
	Dim ycurrentHeight = oLine2.Length ' Current rectangle's height
	If RectIndex = 1 Then ' First dimension
		xOffset = x
		yOffset = y
	ElseIf RectIndex = 2 Then ' Second dimension
		xOffset = x + a + (xprevHeight - xcurrentHeight) / 2
		yOffset = y + a + (yprevHeight - ycurrentHeight) / 2
	Else ' Subsequent dimensions
		xOffset = xprevOffset + a + (xprevHeight - xcurrentHeight) / 2
		yOffset = yprevOffset + a + (yprevHeight - ycurrentHeight) / 2
	xprevOffset = xOffset ' Update xprevOffset for the next rectangle
	yprevOffset = yOffset ' Update yprevOffset for the next rectangle
	xprevHeight = xcurrentHeight ' Update xprevHeight for the next rectangle
	yprevHeight = ycurrentHeight ' Update yprevHeight for the next rectangle
	Dim oDimPositionHorizontal = ThisApplication.TransientGeometry.CreatePoint2d(0, oLine3.StartSketchPoint.Geometry.Y + yOffset) ' Create Point2d objects for dimension text locations with updated offsets
	Dim oDimPositionVertical = ThisApplication.TransientGeometry.CreatePoint2d(oLine2.StartSketchPoint.Geometry.X + xOffset, 0) ' Create Point2d objects for dimension text locations with updated offsets
    Try ' Add dimension constraints to the rectangle
    End Try
    Try
    End Try
	Return oSketch.SketchPoints.Item(oSketch.SketchPoints.Count) 'SketchPoints.Count returns the last added "SketchPoint" in the collection.
End Function
Function CoincidentConstraint(SketchPnt1 As SketchPoint, SketchPnt2 As SketchPoint, Sketch As PlanarSketch)
	Try
		Return Sketch.GeometricConstraints.AddCoincident(SketchPnt1, SketchPnt2)
	Catch ex As Exception  ' Handle the exception if needed
	End Try
End Function
Function MidpointConstraint(Point As SketchPoint, Line As SketchLine, Sketch As PlanarSketch)
	Try
		Return Sketch.GeometricConstraints.AddMidpoint(Point, Line)
	End Try
End Function
      		Exit For
    Next
End Function
        Return Nothing ' Return Nothing in case of invalid input
    ' Create points
    Dim cornerPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(halfLength * 2, halfWidth * 2)
    ' Validate points
        Return Nothing ' Return Nothing if points are not valid
    Try
        ' Add rectangle
        Return oSketch.SketchLines.AddAsTwoPointRectangle(centerPoint, cornerPoint)
        Return Nothing ' Return Nothing on failure
    End Try
End Function
Function GetMidpointOfLinesMiddlePoint(oSketch As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator) As SketchPoint
    Dim midpointSketchPoint As SketchPoint = oSketch.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(2, 1))
	MidpointConstraint(midpointSketchPoint, oRectangleLines(1) , oSketch)
    Return midpointSketchPoint    ' Return the midpoint as a Point2d object
End Function
Function GetRectThirdlineMidPoint(oSketch As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator) As SketchPoint
    Dim midpointRectThirdLinePoint As SketchPoint = oSketch.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(3, 2))
	MidpointConstraint(midpointRectThirdLinePoint, oRectangleLines(3) , oSketch)
    Return midpointRectThirdLinePoint    ' Return the midpoint as a Point2d object
End Function
Sub ShowRectangleList(Rectangles As List(Of Tuple(Of Double, Double)))
    Dim TotalRects As Byte = Rectangles.Count
	Dim rectangleListString As String = "Total number of rectangles: " & TotalRects.ToString()
	rectangleListString &= vbCrLf & "Current list of rectangles:" & vbCrLf
    For Each rect In Rectangles
    Next
End Sub
Function DocumentTypeValidation ( oCurrentSession As Inventor.Application ) As Boolean
	If oCurrentSession.ActiveDocument Is Nothing Then
		MsgBox("No active document found.")
		Return False
	Dim Doc As PartDocument = TryCast(oCurrentSession.ActiveDocument, PartDocument)
	If Doc Is Nothing Then
		MessageBox.Show("This rule works with part documents only.", "iLogic Rule",MessageBoxButtons.OK, MessageBoxIcon.Warning)
		Return False
	Return True ' If the function reaches here, the active document is a part document
End Function
It creates rectangles side by side like this.
Dimensions are just messed up 🙂  I will try to relocate those. I actually want rectangles in my sketch to be mirrored after all rectangles created. But I searched, so far, seems like iLogic doesnt provide mirror feature. Is there anyway to mirror something in skecth via APİ ?
Message 9 of 16
Mehmet_Fatih_Turker
Hi @J-Camper thanks for sharing
Message 10 of 16
J-Camper
The mirror sketch feature builds SymmetryConstraints for new sketch entities.  for line segments, this is as simple as applying symmetry of the start and end points.  For curves, radial and elliptical, it adds symmetry constraints between the center point, sketchcurve, and start/endpoints [if an arc]. Here is test code to examine any Symmetry Constraints in a given sketch:
Dim PickSketch As PlanarSketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select a planar sketch")
If IsNothing(PickSketch) Then Exit Sub ' If nothing gets selected then we're done
For Each geoCon As GeometricConstraint In PickSketch.GeometricConstraints
	If geoCon.Type <> ObjectTypeEnum.kSymmetryConstraintObject Then Logger.Trace(CType(geoCon.Type, ObjectTypeEnum).ToString) : Continue For
	Dim Highlighter As HighlightSet = ThisApplication.ActiveDocument.CreateHighlightSet
	Highlighter.AddItem(geoCon.EntityOne)
	Highlighter.AddItem(geoCon.EntityTwo)
	Highlighter.AddItem(geoCon.SymmetryLine)
	MessageBox.Show("SymmetryConstraint Entities and Symmetry Line", "Pause")
	Highlighter.Clear
Next
In order to mimic the mirror feature you would need to create sketch entities of the same type as the originals you want mirrored.  Then create symmetry constraints to define the new entities.
Let me know if you have any questions.
Message 11 of 16
Mehmet_Fatih_Turker
Option Explicit On
Option Infer Off
Sub Main()
	Dim oPartCompDef = oThisSession.ActiveDocument.ComponentDefinition
	Dim length As Double = 0.0
	Dim xLength As Double = 0.0
	Dim isdone As Boolean = False
	Do
		Dim InputTuple As Tuple(Of Double, Double) = GetRectangleDimensions(RectNo, isdone)
			Exit Do
		If RectNo = 1 Then
			 xLength = InputTuple.Item1
		RectNo += 1
	Loop
	ShowList(rectangles)
	Dim SketchforCore As PlanarSketch = oPartCompDef.Sketches.Add(oPartCompDef.WorkPlanes.Item(3))'Create sketch after getting rect values
	Dim oOriginPoint As SketchPoint = CheckOriginSketchPoint(oPartCompDef, SketchforCore)
	Dim symmetryLine As SketchLine = CheckYSketchAxis(oPartCompDef, SketchforCore)
	symmetryLine.Construction = True
    For Each rect As Tuple(Of Double, Double) In rectangles
		Dim currentRectangleLines  = DrawRectangle(SketchforCore,rect.Item1, rect.Item2) ' Draw the rectangle using the dimensions
		ApplyDimsofRectangles(SketchforCore, currentRectangleLines)
    	Dim currentMidOfFirstLine = GetMidpointOfLinesMiddlePoint(SketchforCore, currentRectangleLines)
    	Dim currentMidOfThirdLine = GetRectThirdlineMidPoint(SketchforCore, currentRectangleLines)
        	CoincidentConstraint(currentMidOfFirstLine, oOriginPoint, SketchforCore) ' First rectangle: Constrain its first line midpoint to the origin
		Else
        	CoincidentConstraint(currentMidOfFirstLine, prevMidOfThirdLine, SketchforCore) ' Constrain the first line midpoint of the current rectangle to the third line midpoint of the previous rectangle
		If RectIndex < rectangles.Count Then
			Dim symmetryRect = SketchforCore.SketchLines.AddAsTwoPointRectangle(ThisApplication.TransientGeometry.CreatePoint2d(0, 0), ThisApplication.TransientGeometry.CreatePoint2d(1, 1))
			AddSymmetryForRectangle(SketchforCore, currentRectangleLines, symmetryRect, symmetryLine) ' Apply symmetry constraints to the rectangle
		RectIndex += 1
    Next
	ThisApplication.ActiveView.GoHome()
	ThisApplication.ActiveDocument.save()
End Sub
Function ApplyDimsofRectangles(sketchtoApplyDims As PlanarSketch, rectangleLines As SketchEntitiesEnumerator ) As SketchPoint
	Dim doc As PartDocument = ThisApplication.ActiveDocument
	Dim compDef As PartComponentDefinition = doc.ComponentDefinition
	Dim params As Inventor.Parameters = compDef.Parameters
	Dim horDimName As String = "Length_"
    Dim verDimName As String = "Width_"
	Dim oLine3 = rectangleLines(3) ' Extract the lines for dimensioning
    Dim oLine2 = rectangleLines(2) ' Extract the lines for dimensioning
	Dim oLengthDimPositionHorizontal = ThisApplication.TransientGeometry.CreatePoint2d(0, 0) ' Create Point2d for dimension text locations
	Dim oWidthDimPositionVertical = ThisApplication.TransientGeometry.CreatePoint2d(0, 0) ' Create Point2d for dimension text locations
	Dim indexHor As Byte = 1
	Dim indexVer As Byte = 1
    Try ' Add horizontal dimension constraint
		Dim horizontalDim As DimensionConstraint
        horizontalDim = sketchtoApplyDims.DimensionConstraints.AddTwoPointDistance(oLine2.StartSketchPoint, oLine2.EndSketchPoint, DimensionOrientationEnum.kVerticalDim, oWidthDimPositionVertical)
		Dim newNameHor As String = horDimName & indexHor.ToString()
		Dim HorNameExists As Boolean = True
		While HorNameExists 'İs true
			HorNameExists = False 'setting variable to false imidiately
			For Each param As Inventor.Parameter In params ' iterates over all existing parameters  in the part document to check if the name already exists
				If param.Name = newNameHor Then
					HorNameExists = True 'setting variable to true if name matches found
					Exit For ' exits for each loop with setting variable to true in order to keep the while loop running
			Next
			If HorNameExists Then ' if variable is true, program gets into if
				indexHor += 1 ' rise up one by one
				newNameHor = horDimName & indexHor.ToString() ' assign new name
		End While 'ends while if variable is false as set at the beginning of loop / iterates again if variable is true
		horizontalDim.Parameter.Name = newNameHor ' asigns new name
    End Try
    Try ' Add vertical dimension constraint
        Dim verticalDim As DimensionConstraint
        verticalDim = sketchtoApplyDims.DimensionConstraints.AddTwoPointDistance(oLine3.StartSketchPoint, oLine3.EndSketchPoint, DimensionOrientationEnum.kHorizontalDim, oLengthDimPositionHorizontal)
		Dim newNameVer As String = verDimName & indexVer.ToString()
		Dim VerNameExists As Boolean = True
		While VerNameExists ' same as above
			VerNameExists=False
				If param.Name = newNameVer Then
					VerNameExists = True
					Exit For
			Next
			If VerNameExists Then
				indexVer += 1
				newNameVer = verDimName & indexVer.ToString()
		End While
		verticalDim.Parameter.Name = newNameVer
    End Try
	Return sketchtoApplyDims.SketchPoints.Item(sketchtoApplyDims.SketchPoints.Count) ' Return the last added SketchPoint
End Function
Function GetRectangleDimensions(thingCount As Byte, ByRef donetoFinish As Boolean) As Tuple(Of Double, Double)
    Inputlength = GetValidatedInput("Enter the length of the " & thingCount.ToString() & " rectangle (or type 'd' to finish)", "Rectangle", donetoFinish) ' Get length with validation
    If donetoFinish Then Return Nothing ' Exit if the user finishes input during length entry
    Do
        Inputwidth = GetValidatedInput("Enter the width of the " & thingCount.ToString() & " rectangle ", "Rectangle", donetoFinish) ' Get width with validation, user cannot exit here
            donetoFinish = False ' Reset done flag so that the user cannot exit at this stage
        Else
    Loop
End Function
Function GetValidatedInput(prompt As String, title As String, ByRef isDonetoValid As Boolean) As Double
            isDonetoValid = True
        Try
            If result > 0 Then
            Else
        End Try
    End While
    Return result
End Function
Function CheckYSketchAxis (ComponentDefinition As PartComponentDefinition, Sketch As PlanarSketch) As SketchLine
    Dim SketchYAxis As SketchLine = Sketch.AddByProjectingEntity(ComponentDefinition.WorkAxes(2))
    Return SketchYAxis
End Function
Function CoincidentConstraint(Basepoint As SketchPoint, SecondPointtoSellect As SketchPoint, SketchforCoincidentConstraint As PlanarSketch)
	Try
		Return SketchforCoincidentConstraint.GeometricConstraints.AddCoincident(Basepoint, SecondPointtoSellect)
	End Try
End Function
Function MidpointConstraint(Point As SketchPoint, baseLine As SketchLine, SketchforMidpointConstraint As PlanarSketch)
	Try
		Return SketchforMidpointConstraint.GeometricConstraints.AddMidpoint(Point, baseLine)
	End Try
End Function
Function AddSymmetryForRectangle(Sketch As PlanarSketch, thingforBase As SketchEntitiesEnumerator, thingforSymmetry As SketchEntitiesEnumerator, symmetryLine As SketchLine)
	Try
        Dim lineCount As Integer = thingforBase.Count ' Get the count of lines in the rectangle
        For i As Integer = 1 To lineCount ' Loop through all lines dynamically
		   Sketch.GeometricConstraints.AddSymmetry(thingforBase(i), thingforSymmetry(i), symmetryLine)
	    Next
		MessageBox.Show("Symmetry Constraint failed: " & ex.Message)
    End Try
End Function
Function CheckOriginSketchPoint(ComponentDefinition As PartComponentDefinition, Sketch As PlanarSketch) As SketchPoint
      		Exit For
    Next
        OriginSketchPoint = Sketch.AddByProjectingEntity(ComponentDefinition.WorkPoints(1))
End Function
Function DrawRectangle(sketchforRect As PlanarSketch, length As Double, width As Double) As SketchEntitiesEnumerator
    If length <= 0 Or width <= 0 Then ' Validate dimensions
    ' Create points
    Dim cornerPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(width/10, length/10)
    ' Validate points
    Try
        Return sketchforRect.SketchLines.AddAsTwoPointRectangle(centerPoint, cornerPoint) ' Add rectangle
    End Try
End Function
Function GetMidpointOfLinesMiddlePoint(sketchforMidPoint As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator) As SketchPoint
    Dim midpointSketchPoint As SketchPoint = sketchforMidPoint.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(2, 1))
	MidpointConstraint(midpointSketchPoint, oRectangleLines(4) , sketchforMidPoint)
End Function
Function GetRectThirdlineMidPoint(sketchforMidPoint As PlanarSketch, oRectangleLines As SketchEntitiesEnumerator) As SketchPoint
    Dim midpointRectThirdLinePoint As SketchPoint = sketchforMidPoint.SketchPoints.Add(ThisApplication.TransientGeometry.CreatePoint2d(3, 2))
	MidpointConstraint(midpointRectThirdLinePoint, oRectangleLines(2) , sketchforMidPoint)
End Function
Sub ShowList(Things As List(Of Tuple(Of Double, Double)))
    Dim TotalThings As Byte = Things.Count
	Dim thingListString As String = "Total number of rectangles: " & TotalThings.ToString()
									thingListString &= vbCrLf & "Current list of rectangles:" & vbCrLf
    For Each thing As Tuple(Of Double, Double) In Things
        thingListString &= "Length: " & thing.Item1 & ", Width: " & thing.Item2 & vbCrLf
    Next
    MessageBox.Show(thingListString, "Rectangle List", MessageBoxButtons.OK, MessageBoxIcon.Information)
End Sub
Function DocumentTypeValidation ( oSession As Inventor.Application ) As Boolean
	If oSession.ActiveDocument Is Nothing Then
		Return False
	Dim Doc As PartDocument = TryCast(oSession.ActiveDocument, PartDocument)
		Return False
End Function
@J-Camper Hi again 🙂 Hope this response will not be deleted at all because I couldn't post this response for 2 or 3 times. Thank you for your response and wise approach, it helped me a lot. I first draw my actual rect and random rect as second. then created the function like this
	Try
	    Next
    End Try
End Function
Then used it in main sub like this
and end product is this
 İts the almost end of this stage 🙂 . As last question, I wanted to relocate dimensions to a proper positions but seems like couldn't menage to do that. First I stored them in Lists regarding their classes like this
Function AlignHorizontalAndVerticalDimensions(activeSketch As PlanarSketch) As Boolean
	Dim horDims As New List(Of DimensionConstraint)
    Dim verDims As New List(Of DimensionConstraint)
	Dim oDim As DimensionConstraint
    For Each oDim In activeSketch.DimensionConstraints
        MessageBox.Show("For succeed")
        ' Check for horizontal and vertical dimensions using DimensionTypeEnum
        If oDim.Type = DimensionTypeEnum.kHorizontalDimensionType Then
            oDim.TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(5, 7)
            MessageBox.Show("Horizontal dimension aligned")
            horDims.Add(oDim) ' Store the horizontal dimension if needed
        ElseIf oDim.Type = DimensionTypeEnum.kVerticalDimensionType Then
            oDim.TextPoint = ThisApplication.TransientGeometry.CreatePoint2d(15, 8)
            MessageBox.Show("Vertical dimension aligned")
            verDims.Add(oDim) ' Store the vertical dimension if needed
    Next
	Return True
End Function
and used it in main sub but didnt work so far. Is there any suggestion ?
From that, I will open new topic to ask new question 🙂
Message 12 of 16
J-Camper
You are making the dimension constraints with (0,0) as the text point.  If you change the Text points to be:
Vertical Dimension text point = (<X value of Horizontal line segment midpoint> + <offset value>, <Y value of Horizontal line segment midpoint>)
Horizontal Dimension text point = (<X value of Vertical line segment midpoint>, <Y value of Vertical line segment midpoint> + <offset value>)
in your "ApplyDimsofRectangles" function then your dimensions should be in logical positions:
	Dim oLengthDimPositionHorizontal = ThisApplication.TransientGeometry.CreatePoint2d(oLine3.Geometry.MidPoint.X+2, oLine3.Geometry.MidPoint.Y) ' Create Point2d for dimension text locations
	Dim oWidthDimPositionVertical = ThisApplication.TransientGeometry.CreatePoint2d(oLine2.Geometry.MidPoint.X, oLine2.Geometry.MidPoint.Y+2) ' Create Point2d for dimension text locations
Message 13 of 16
Mehmet_Fatih_Turker
What I mean was to keep them in a line like for instance, all dimensions at this position at first
Then, to that position
Program creates rects at default location then apply dimensions then moves those rectangles to required position.When program carries rects to regarding places, dimensions are floating freely, Which means, even though I apply positioning at the stage of ApplyDimsofRectangles, it doesnt remain at required position in the next stages.
Message 14 of 16
J-Camper
Okay, the problem you have with your rule is you are checking and ObjectTypeEnum (oDim.Type) against a DimensionTypeEnum, which will always return false and never actually do what is in the If block.
I worked it out in the code below for 2 derived classes of the dimensionconstraint:
Sub Main
	Dim PickSketch As PlanarSketch = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kSketchObjectFilter, "Select")
	Dim DimCons As List (Of List(Of DimensionConstraint)) = AlignHorizontalAndVerticalDimensions(PickSketch)
End Sub
Function AlignHorizontalAndVerticalDimensions(activeSketch As PlanarSketch) As List(Of List(Of DimensionConstraint))
	Dim OutPutList As New List(Of List(Of DimensionConstraint))
    For Each oDim As DimensionConstraint In activeSketch.DimensionConstraints
		Dim DimConClasification As DimensionOrientationEnum = GetOrientationFromDimensionConstraint(oDim)
		If DimConClasification = Nothing Then Logger.Debug("Function: ""GetOrientationFromDimensionConstraint"" returned ""Nothing""") : Continue For
        If DimConClasification = DimensionOrientationEnum.kHorizontalDim
            'MessageBox.Show("Horizontal dimension aligned")
        ElseIf DimConClasification = DimensionOrientationEnum.kVerticalDim
            'MessageBox.Show("Vertical dimension aligned")
		Else
			Logger.Debug("Dimension constraint clasification: " & CType(DimConClasification, DimensionOrientationEnum).ToString)
    Next
	If horDims.Count > 0 Then OutPutList.Add(horDims)
	If verDims.Count > 0 Then OutPutList.Add(verDims)
	Return OutPutList
End Function
Function GetOrientationFromDimensionConstraint(DimCon As DimensionConstraint) As DimensionOrientationEnum
	Select Case DimCon.Type
		Case ObjectTypeEnum.kTwoPointDistanceDimConstraintObject
			Return DimCon.Orientation 'Can be set to aligned, but in current orientation appears vertical or horizontal
		Case ObjectTypeEnum.kOffsetDimConstraintObject
			Dim OffsetSkLine As SketchLine = TryCast(DimCon.Line, SketchLine)
			If OffsetSkLine Is Nothing Then
				Logger.Debug("DimensionConstraint, of type OffsetDimConstraint, did not have a line as offset object")
			Else
				Dim Xdif As Double = OffsetSkLine.Geometry.StartPoint.X - OffsetSkLine.Geometry.EndPoint.X
				Dim Ydif As Double = OffsetSkLine.Geometry.StartPoint.Y - OffsetSkLine.Geometry.EndPoint.Y
				If Xdif = 0 And Ydif = 0
					Logger.Debug("SketchLine X&Y differences are both Zero")
				Else If Xdif = 0
					Return DimensionOrientationEnum.kHorizontalDim
				Else If Ydif = 0
					Return DimensionOrientationEnum.kVerticalDim
				Else
					Return DimensionOrientationEnum.kAlignedDim
		Case Else
			Dim DerivedClass As String = CType(DimCon.Type, ObjectTypeEnum).ToString
			DerivedClass = Right(DerivedClass, DerivedClass.Length - 1)
			DerivedClass = Left(DerivedClass, DerivedClass.Length - 6)
			Logger.Debug("DimensionConstraint Orientation not programed for derived class: " & DerivedClass)
	End Select
	Return Nothing
End Function
Message 15 of 16
Mehmet_Fatih_Turker
@J-Camper
How come did you reach to DimCon.Orientation or DimCon.Line properties ? I couldnt find in DimensionConstraint object. Also it doesnt listed in
https://help.autodesk.com/view/INVNTOR/2023/ENU/?guid=GUID-7CDE8986-36C4-4AC6-B88B-55481AD3AD5D
Message 16 of 16
J-Camper
At the bottom of that web page, there are Derived classes listed.  Derived classes contain methods/properties from the base Class, but also their own methods/properties, which are not in the base.  The "OffsetDim" and "TwoPointDistanceDim" Constraints are the two derived classes for linear dimensions:
In the code I posted, I check the ObjectTypeEnum, which specifically indicates one of the derived classes instead of the base class, and then process the constraint per the most direct available methods/properties of the specific derived class.
